Home > Puma (Tdci) > 2012 90 SW - Sticking clutch :( |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
It should rev match with the next gear, supposed to save wear Original Member Pie n Pea Club.
110 HCPU Tipper |
29th Jan 2013 7:24pm |
SWChris Member Since: 17 Jan 2013 Location: North Wales Posts: 14 |
I see, so this is totally normal?
It almost feels like the revs are sticking!! |
29th Jan 2013 7:29pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
emmision control i have been told...you'll get use to t
29th Jan 2013 9:31pm |
Ken Graham Member Since: 26 Jan 2013 Location: Glasgow Posts: 21 |
Hi Chris
Check out my post re clutch switch and ecu . Seems like L/R have created a monster with this feature, shame they dont know how to fix it ! Cheers Ken. |
17th Feb 2013 5:43pm |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Entirely normal - the ECU holds the revs higher for some good theoretical reason, which doesn't appear to work so well in real life... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
17th Feb 2013 5:57pm |
Mine doesn't have the flat spot you are referring to Ken, so not quite as severe a problem as you are having.
I've adapted my driving style to it now, its actually very helpful when pulling the trailer. |
17th Feb 2013 6:00pm |
Mine seems to respond better under load also
17th Feb 2013 6:27pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Stratstone!!!!! Best of luck with that |
17th Feb 2013 6:55pm |
It's ok, any warranty work will be undertaken either by Hunters of Chester or Conwy Land Rover. The only run in ive had thus far is over the spare key which they lost. |
17th Feb 2013 6:59pm |
Good to hear that mate, I had months of bother with Stratstones. Solihull were the worst, in fact beyond belief at times but Stockton on Tees were as bad at times. I wouldn't bug a can of oil from them, never mind a car!
17th Feb 2013 7:10pm |
