Home > Puma (Tdci) > 2012 90 SW - Sticking clutch :(
SWChris
2012 Defender 90 Puma 2.2 XS CSW Java Black
I have just bought a 2012 defender 90 with 3800 miles on the clock, an ex-demo from Stratstone in Stockton-on-Tees.
When changing up through the gears, i.e building revs to 3500rpm, I depress the clutch to select a new gear, the rev counter drops as it should but then sticks at 2000rpm for roughly 1-1.5 seconds then drops down again.
Is this normal?
Post #206587 29th Jan 2013 7:16pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
It should rev match with the next gear, supposed to save wear Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #206590 29th Jan 2013 7:24pm
SWChris
I see, so this is totally normal?
It almost feels like the revs are sticking!!
Post #206595 29th Jan 2013 7:29pm
T1G UP
emmision control i have been told...you'll get use to t
Post #206655 29th Jan 2013 9:31pm
Ken Graham
United Kingdom 2013 Defender 90 Puma 2.2 HT Java Black
Hi Chris
Check out my post re clutch switch and ecu .
Seems like L/R have created a monster with this feature, shame they dont know how to fix it !
Cheers Ken.
Post #211920 17th Feb 2013 5:43pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Entirely normal - the ECU holds the revs higher for some good theoretical reason, which doesn't appear to work so well in real life... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #211921 17th Feb 2013 5:57pm
SWChris
Mine doesn't have the flat spot you are referring to Ken, so not quite as severe a problem as you are having.
I've adapted my driving style to it now, its actually very helpful when pulling the trailer.
Post #211922 17th Feb 2013 6:00pm
Ken Graham
Mine seems to respond better under load also Confused
Post #211925 17th Feb 2013 6:27pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Re: 2012 90 SW - Sticking clutch :(
Is this normal?
Stratstone!!!!! Best of luck with that Shocked
Post #211928 17th Feb 2013 6:55pm
SWChris
Is this normal?
It's ok, any warranty work will be undertaken either by Hunters of Chester or Conwy Land Rover. The only run in ive had thus far is over the spare key which they lost.
Post #211929 17th Feb 2013 6:59pm
borderterrier
Good to hear that mate, I had months of bother with Stratstones. Solihull were the worst, in fact beyond belief at times but Stockton on Tees were as bad at times. I wouldn't bug a can of oil from them, never mind a car!
Post #211936 17th Feb 2013 7:10pm
