Home > Puma (Tdci) > Interior lighting fault.
RED-DOT
My 90xs has no interior lights working at all and alarm sounds on locking. Yesterday i slammed the rear door and they worked fine until i re-opened the door and the fronts worked ok. The switch at the back is fine and any ideas or which route does the wiring take as it may be faulty?? Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #211871 17th Feb 2013 10:43am
K9F
PM sent. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #211872 17th Feb 2013 10:47am
K9F
Details sent. Hope it helps...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #211873 17th Feb 2013 11:04am
RED-DOT
Got it Mal...just need the wiring route to the back door now. Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #211886 17th Feb 2013 11:49am
K9F
Thumbs Up Welcome! Happy hunting and hope you get it finally sorted once and for all. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #211887 17th Feb 2013 11:55am
