Home > Technical > Standard Pitch and Roll? |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I noticed that it's not really defined anywhere (that I can find), apart from approach/departure.
So what is the figures for a standard 90/110 for Pitch and Roll? I have a figure of 45deg in my mind for the roll? Ta! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
14th Feb 2013 8:06pm |
Not entirely sure what you mean by 'pitch' but I'm guessing 'roll' refers to ability to traverse side slopes? If so then I doubt Land Rover would claim a figure as there are too many variables and too much scope for things to go badly. I suspect that given a nice even slope and no unusual loadings that 45 degrees would be doable. It is safe to say that the vast majority of people would bottle out before that limit was reached though. Darren
14th Feb 2013 8:27pm |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 |
Most people bottle it well before 45 degrees. It's a long way over!
Andy. |
14th Feb 2013 8:35pm |
By pitch I mean fore and aft, to be honest its probably a lot higher than the approach and departure angles anyway. Craig Rogers
Well, Land Rover quote a maximum gradient figure of 45 degrees, which I guess is the same thing? Darren
14th Feb 2013 8:44pm |
Is this the sort of thing you meant?
Andy. |
15th Feb 2013 9:41pm |
There's this one too.
http://www.expeditionlandrover.info/LRcoilerSpecs.htm Andy. |
15th Feb 2013 10:03pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3648 |
the angle it will reach before tipping over sideways will vary quite a lot on what you do to the landy
wider wheels will increase the angle before you end up on your side, as will lowering it, or adding weigh below the centre of gravity (side steps steering guards axle guards etc) longer springs or adding weight up high will reduce the angle (roof racks roll cages etc) a standard Land Rover 90 is about 40 degrees DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
16th Feb 2013 7:48am |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
According to my 2011 Defender catalogue:
Max gradient all 45 degrees Approach angle all 49 degrees Departure angle 90 - 47 degrees 110/130 - 35 degrees Ramp break 90 - 147, 110 - 150, 130 - 153 Traverse angle all 35 degrees |
16th Feb 2013 11:59am |
