Home > Technical > Standard Pitch and Roll?
x-isle
I noticed that it's not really defined anywhere (that I can find), apart from approach/departure.
So what is the figures for a standard 90/110 for Pitch and Roll? I have a figure of 45deg in my mind for the roll?
Ta! Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #211253 14th Feb 2013 8:06pm
Not entirely sure what you mean by 'pitch' but I'm guessing 'roll' refers to ability to traverse side slopes? If so then I doubt Land Rover would claim a figure as there are too many variables and too much scope for things to go badly. I suspect that given a nice even slope and no unusual loadings that 45 degrees would be doable. It is safe to say that the vast majority of people would bottle out before that limit was reached though. Darren
Post #211258 14th Feb 2013 8:27pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Most people bottle it well before 45 degrees. It's a long way over!
Andy.
Post #211263 14th Feb 2013 8:35pm
x-isle
Thumbs Up By pitch I mean fore and aft, to be honest its probably a lot higher than the approach and departure angles anyway. Craig Rogers
2007 Puma 110 XS
Post #211264 14th Feb 2013 8:35pm
Well, Land Rover quote a maximum gradient figure of 45 degrees, which I guess is the same thing? Darren
Post #211267 14th Feb 2013 8:44pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Can't quite remember but think the maximum roll angle is in the 30's
One of my mates builds the courses for Land Rover for them to show off what they can do ( at launch shows and G4 challenge courses) the maximum roll was shown with one side of the truck driving up onto the track of a large 360 digger. That was pretty unnerving so wouldn't like to get close to 45degrees !!!
Post #211536 15th Feb 2013 9:04pm
Andy Jeff
Is this the sort of thing you meant?
Andy.
Post #211548 15th Feb 2013 9:41pm
Andy Jeff
Post #211552 15th Feb 2013 10:03pm
LR90XS2011
the angle it will reach before tipping over sideways will vary quite a lot on what you do to the landy
wider wheels will increase the angle before you end up on your side, as will lowering it, or adding weigh below the centre of gravity (side steps steering guards axle guards etc)
longer springs or adding weight up high will reduce the angle (roof racks roll cages etc)
a standard Land Rover 90 is about 40 degrees DEFENDER 90 TDCI XS,
Post #211592 16th Feb 2013 7:48am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
According to my 2011 Defender catalogue:
Max gradient all 45 degrees
Approach angle all 49 degrees
Departure angle 90 - 47 degrees 110/130 - 35 degrees
Ramp break 90 - 147, 110 - 150, 130 - 153
Traverse angle all 35 degrees
Post #211647 16th Feb 2013 11:59am
