Home > Technical > What is this noise?
Page 1 of 3 123>
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
What is this noise?
OK can anyone tell me what this noise from my Puma is?
http://www.youtube.com/watch?v=WoPvoSkR26Y
Here are the symptoms:
  • It always gives 5 distinct clonks after the engine stops
  • If you immediatly turn the ignition ON again at time of stopping it doesn't do it. This would suggest it is electronic.
  • It does occassionaly give one of clonk noise when running (this is heard on the video at about 40sec mark)
  • There is no noticable problem with the engine, turbo etc.
  • There are no fault codes (DTC's) logged.
  • It's been like this now for over three months and is "somewhat" annoying.
I'm wondering if it is the waste gate but it appears to be coming from the passenger's side rear of the engine (possibly from the area shown in the first part of the video). 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21133 3rd Jan 2010 9:47am
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
NOISE
Mine does that as well, I have been told by Exeter ,Landrover Dealer that it is the EGR self cleaning itself when you switch the engine off and its nothing to worry about its meant to do it, was a bit worrying at first but dont even notice it now.
Post #21135 3rd Jan 2010 10:18am
dm_td5
Sounds awfully loud though so I'm thinking if it is EGR then I need to get it replaced. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21136 3rd Jan 2010 10:38am
Grockle
ours doesn't do it,I've asked a couple of mates with Pumas neither does theres,so as you say Derek perhaps it needs changing. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #21137 3rd Jan 2010 11:11am
110SEB
Ours did it and the EGR valve was changed. It still does it though, albeit a little quieter - I don't think it's anything to worry about.
You might as well get it looked at while the warranty is there.
Post #21139 3rd Jan 2010 11:23am
dm_td5
Looks like the answer popped up on AULRO forum first. EGR valve cleaning cycle. But it does appear to be excessively noisy. It will have to wait until I can drive out the 1100km's to the dealers in June or July this year as the track out of town is now well and truly impassable after 4 days of good monsoonal rain. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21140 3rd Jan 2010 11:29am
Grockle
can't you fly it out from the areodrome to the dealers Derek Wink 2.4 90 XS
Post #21142 3rd Jan 2010 11:33am
mse
Perfectly normal - ive not yet been in one that doesnt do it, they all should.
I suggest yours is loud as you have the bonnet up.
If you need a pilot to fly you any where, ill specially come across from the UK to help Thumbs Up Mike
Post #21147 3rd Jan 2010 11:49am
dm_td5
It's bad enough to ship it out on the barge. Works out about AU$3000 one way to Darwin. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21148 3rd Jan 2010 12:08pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Oddly that is quite a loud noise but like mse said your bonnet is up so I might give it a try and put the video up on youtube just to be certain since my car is going this saturday for the park brake recall issue. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #21153 3rd Jan 2010 3:57pm
dgardel
Italy
please no false alarms......
it is the EGR cleaning cycle when you swich off the engine. it,s normal!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21154 3rd Jan 2010 4:15pm
T1G UP
ever thought of removing the EGR....
Post #21161 3rd Jan 2010 6:29pm
YORKSHIRELAD
I had mine checked out and was told it was normal. 1963 Series 2A truck cab
2008 110 SW
Post #21169 3rd Jan 2010 8:05pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Same noise and number of cycles on mine since new but more muted from the cab. Always assumed it was normal!
Post #21170 3rd Jan 2010 8:21pm
dm_td5
I should point out I can here this from over 10 metres away and also from inside the house, it's very loud. I'm glad it's "normal" at least, as here I was thinking I was the only one. The other two Puma's in town don't do this or at least it's not noticeable. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21183 4th Jan 2010 7:59am
Page 1 of 3 123>
