Home > Technical > Battery Info, deep cycle and starter difference! |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
I went for Odyssey PCT1500 x2 - have both good cold cranking amps and can cope with deep discharge. Not cheap but you can get 2 under the front seat. Also have very good cold performance and retain a relatively high proportion of voltage at low temps
13th Feb 2013 6:24pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8099 |
Simon R is the man to speak to about deep cycle batts and their use for normal use.
i use deep cycle batts as normal vehicle batts on 5 vehicles. some of them are parrallel setups. haev run like it for 6years on one no probs on any of them, Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Feb 2013 8:17pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Thanks for the replies.
I see after a Google some are using the Enduroline ones as a starter battery in their Disco's and to use for their winches. I could get a higher amp rated 'house' battery but i think you are meant to have similar/same batteries for charging in parallel! Odysseys would be nice but out of my bracket Steve...Endurolines are £175 for both and panels etc £100. Sunstore.co.uk sell cheap panels if anyone is interested. |
14th Feb 2013 7:43am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Three types of batteries.
1) Starter battery. Capable of giving large current draw and then recharged straight away 2) Leisure battery. Provides low current, for long periods of time and can be deeply discharged 3) Combined starter/leisure battery. Combines both functions. Chances are that if you used a leisure battery to start a vehicle then whilst it may do it but you may well damage/buckle the plates etc. Depending on how you are going to use your vehicle then I suggest that a dual battery system using combined starter/leisure batteries with a relay capable of carrying starter currents. Reason being the principle aim of your battery system is to start the engine. F you can not start the engine you could be up the creek etc. Our twin battery system uses Odyssey batteries with a 200 amp relay Brendan |
14th Feb 2013 9:03am |
I think this is something of a myth. Think of the tens of thousands of caravans that have leisure batteries charged in parallel by the towing vehicle. The two batteries in those cases won't be similar but the systems work without issue. When I owned a Desert Wolf trailer, it had two 100 amp leisure batteries on board that were both charged from my Discovery fitted with its' standard starting battery. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Feb 2013 9:47am |
http://www.tayna.co.uk/Numax-CXV30HMF-P3672.html
i have run these as vehicles batts, two in parallel. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Feb 2013 8:33pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Zag
I can guess what you want them for,, I use 6 identical deep cycle leisure batteries,, 5 as house batteries and one as the start, never a problem, but do change them as a matter of course after 5 years !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
14th Feb 2013 10:31pm |
I think it is more applicable to when you want the functionality to use both in parallel to start the engine. |
16th Feb 2013 9:06am |
