Home > Puma (Tdci) > Puma Chassis - TD5 Chassis
555SUB
England 2007 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Is the Puma Chassis a TD5 Chassis or was there further modifications added to a TD5 chassis or even a new puma chassis made? Does a Puma engine and gearbox fit a TD5 chassis without further modifications?
Also is the suspension the same as TD5 or is this again new design and as such TD5 equipment / upgrades will not directly fit / bolt on.
Dave
Post #21037 1st Jan 2010 2:36pm
mse
There are some differencies between the puma and td5 chassis and some major ones between the 300 and puma ones.
Suspension i understand is different too - but nothing major in that regard, just spring rates/loads i understand they changed on the 90. Mike
Post #21061 1st Jan 2010 8:07pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Suspension (at least on the 110) is the same as the Tdi and Td5. The only difference being the front springs are no longer handed and are now both the same as the passenger's side of the previous models. Strangly if you then go to HD springs in the front they are still the same old handed ones. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #21069 1st Jan 2010 11:11pm
555SUB
So from your replies fitting a Puma engine and gearbox would fit into a TD5 110 Chassis.
Dave
Post #21084 2nd Jan 2010 12:38pm
TJ101
Dave
Would fit,, with some re working of the engine / gearbox mounts, gearbox tunnel, etc,,
Make sure you get the engine loom and ecu etc,, and the bonnet Exclamation California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #21095 2nd Jan 2010 5:29pm
RobKeay
Got different camber angle on tdci and shocks are new. The engine sits different, ashcroft had trouble getting the auto box to fit due to engine angle.
Post #21115 2nd Jan 2010 10:51pm
