Home > My Defender > The FCX Defender 130 build thread |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
Cut a hole .....
11th Feb 2013 10:55am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20192 |
I kinda meant what with.... NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
11th Feb 2013 11:03am |
Sorry Steve
I used a small drill bit, drilled around the perimeter and then finished off with a file. I've got a top of the range all singing all dancing Dremel and the poxy thing wont allow me to open the chuck |
11th Feb 2013 11:13am |
I pondered for ages between the 'Genuine' Dremel and a much cheqper 'copy', might as well have gone for the copy as I've only used it a handful of times and now it's !
11th Feb 2013 12:25pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5008 |
Blimey Matt, just seen this thread you've been busy. Great work.
Looking forward to seeing her again and Zagging her soon... |
11th Feb 2013 12:43pm |
Hello mate, yes I have
I think it may still be a bit cold to Zag her yet |
11th Feb 2013 12:45pm |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
Hi Matt,
Your doors look well silenced. Did you Dynamat the door skin, then Dynamat over the polythene barrier and Dynalined over that? The doors must close like a BMWs now. |
11th Feb 2013 3:17pm |
Hi,
On the Puma they no longer have a polythene barrier, it's just a material very similar to the Dynaliner. I removed and discarded the LR stuff, Dynamat'd the door skin itself, then Dynamat'd where the LR stuff was and then Dynaline'd on top of that, they sound great and now they're bullet proof as well |
11th Feb 2013 3:21pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
It makes all the difference doesn't it nearly finished my doors BTW I saved up and have now got one of those wing locker lock covers |
11th Feb 2013 5:18pm |
Yes it does, thank you for supplying the stuff
I've finished both doors on the drivers side and started on the passenger rear door. |
11th Feb 2013 5:25pm |
Matt have your wired the relay to your a/c? |
11th Feb 2013 5:33pm |
Not yet, do you know the wire colours on the aircon switch ? (or is that why you're asking me )
11th Feb 2013 5:37pm |
That's why I am asking
11th Feb 2013 5:38pm |
Once I've finished wiring up everything else I'll get the batteries connected and work it out
11th Feb 2013 5:44pm |
