Home > In Car Electronics > Focal Speaker Upgrade |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
It should be there somewhere. Chances are its behind the trim thy have removed.
5th Feb 2013 4:58pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Probably why the stereo flashed error if there was no speaker connected
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2637 |
got the fronts in fine, amp half in, need to connect it to the head unit and battery unit need to get a cable to connect the rear of the head unit to the amp,
the rears, with the covers on the speakers wont fit, the screws are too short because the rear quarters recess around the smaller old speaker anybody else had this ? thanks again all especially ethanicus |
5th Feb 2013 10:43pm |
any ideas where ill get them? the odd course like ones...
Click image to enlarge for others... focals don't fit in this recess properly. |
6th Feb 2013 12:11pm |
Halfords, maplins local ice shop, or make some out of mdf and spray them
6th Feb 2013 12:26pm |
gonna go the longer screws route..
6th Feb 2013 12:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Mud do shallow and deep adaptor rings only about 8 a pair. IIRC 10cm & 13cm. Personally though I think you should be fine with what you have and use longer screws as you say. If the grille overlaps then it doesn't matter it's still flush either way. If the new longer screws don't work drill some new ones.
⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
6th Feb 2013 4:55pm |
When it comes to wiring the amp, I have a kenwood kdc bt92, and the alpine 1200 sub, the 'remote on' on the amp connects to? There's 'ant cont / p cont' and 'steering wheel remote input' / 'remote cont' free,
On the wires out the back of the head unit, there's also a blue cable that goes to nowhere (goes into the adapter) but nothing on the cars side... Have a pic if anybody wants to Shoot me there email to show them Exactly what I mean The 'remote on' has 2 bullet connectors at one end... Looking at the wiring for the head unit, the blue white from the adapter says 'power control' the other blue white spare which is antenna control / power control says 'when using the optional power amplifier... I guess this is the one? |
8th Feb 2013 2:46pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
8th Feb 2013 3:02pm |
ethanicus Member Since: 11 Jan 2013 Location: Surrey Posts: 94 |
Hi, Yes the blue white is the correct wire to use. This will tell the amp to turn on when the head unit is powered up. Just finished fitting my sub so will add some pics shortly. Cheers, Jon |
8th Feb 2013 3:55pm |
Cool, can't wait mine is in, wired up but nothing is happening...
8th Feb 2013 4:10pm |
Make sure you enable the subwoofer output on the head unit (if its an option).
Give me a call if you get stuck. |
8th Feb 2013 4:25pm |
ethanicus (jon) thank you very! much had a lengthy phone call with him, for some reason my car blew 2 fuses on the amp, eventually got it working... difference is amazing. rears still aren't in, think i need a bigger sub to keep up with the focals tho...
8th Feb 2013 6:30pm |
No problem, nothing worse than making a recommendation and then it doesnt work
Just finished the sub install. It makes so much differnce, not max power load but rounds out the sound of the Focals. Few images here: https://www.defender2.net/gallery/thumbnails.php?album=1095 Also added a aux fuse box to support the sub: https://www.defender2.net/gallery/thumbnails.php?album=1096 Last edited by ethanicus on 10th Feb 2013 4:56pm. Edited 1 time in total |
10th Feb 2013 4:24pm |
