![]() | Home > In Car Electronics > DAB aerial - what type and where to place ? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Glad you're sorted bm52. My radio, bought just before Christmas had version 1 DAB software and there is an update to version 1.02 available software on the Kenwood website. Just follow the instructions carefully. It is fairly simple to do.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Cordite72 Member Since: 15 Sep 2011 Location: Salisbury Posts: 26 ![]() ![]() ![]() |
I take it you guys fitted these to a PUMA front windscreen and it works without the signal being downgraded? The audio shop I have been talking to rates the Hirschman http://www.dabonwheels.co.uk/Hirschmann_AU...rial.html, but also fit the new Ford Focus aerial to the sloping front part of the roof. The only other option appears to to be the side window. They believe an external aerial is best.
It's also a shame that the Parrot Asteroid doesn't do DAB, so I am having to buy a DAB adaptor. Grateful for views/advice. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I fitted the recommended Kenwood DAB aerial on the left hand side of the windscreen. It has performed very well, just a couple of weak reception areas when in SE London. otherwise great with very clear reception and clarity.
![]() Kemwood, if I recall, advise 15cm from the top of the screen and in by 7cm. These measurements, bearing in mind the short Puma windscreen, means the aerial is quite low on the screen and i had to move the tax disc holder. Passengers have not commented on whether the aerial obscures vision so I assume it is all OK. BM52 |
I fitted my Kenwood DAB aerial a little higher than recommended, about 10cm from top, and have excellent reception all over S.Wales.
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
A quick pic of the JVC HAL-2 aerial mounted on the wing...
![]() Click image to enlarge It has both FM and DAB outputs. http://www.yorkshireoffroadclub.net/ |
I thought about Hal 2 but I like the normal aerial as I use it like a cats whisker for car parks etc. Comes in quite handy. BM52
Too true bm25.
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
It is my 90 in davew's pic above. With the cage and lift and hd springs I don't even think about going in multistorey or overhead barriered car parks! ![]() ![]() ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Hey guys, just wondering if anyone had any tips to give. I too have bought the same roof/wing mount DAB+FM aerial and aren't getting great signal. Suspect it could be an earth issue? Did you sand down the underside of the wing for better contact? Or use tinfoil etc as it mentions? Does it matter that the wing is aluminium etc? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
I used this splitter fitted using the standard aerial and it works great around here in kent:
http://www.dabonwheels.co.uk/Kinetic_DAA-7...itter.html |
