Home > In Car Electronics > DAB aerial - what type and where to place ?
Page 2 of 2 <12
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Glad you're sorted bm52. My radio, bought just before Christmas had version 1 DAB software and there is an update to version 1.02 available software on the Kenwood website. Just follow the instructions carefully. It is fairly simple to do. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #205035 24th Jan 2013 7:10pm
^^^^ Good advice there. A good thing is as well that they don't continually every five minutes put out an update they usually only come out when absolutely required unlike Apple who keep on updating every couple of months. Some argue keeping the original software is best as there's nothing wrong with it already but the only downside to that is they often release these updates to improve functionality and features and so on. So if you don't you loose out. For example before I did the most recent firmware update on mine I couldn't get album artwork on-screen. Afterwards it's there. Mr. Green Chillin In The Backwoods🇬🇧🇺🇸
Post #205045 24th Jan 2013 7:32pm
Cordite72
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
I take it you guys fitted these to a PUMA front windscreen and it works without the signal being downgraded? The audio shop I have been talking to rates the Hirschman http://www.dabonwheels.co.uk/Hirschmann_AU...rial.html, but also fit the new Ford Focus aerial to the sloping front part of the roof. The only other option appears to to be the side window. They believe an external aerial is best.
It's also a shame that the Parrot Asteroid doesn't do DAB, so I am having to buy a DAB adaptor.
Grateful for views/advice.
Post #207570 2nd Feb 2013 11:20am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I fitted the recommended Kenwood DAB aerial on the left hand side of the windscreen. It has performed very well, just a couple of weak reception areas when in SE London. otherwise great with very clear reception and clarity. Thumbs Up
Kemwood, if I recall, advise 15cm from the top of the screen and in by 7cm. These measurements, bearing in mind the short Puma windscreen, means the aerial is quite low on the screen and i had to move the tax disc holder. Passengers have not commented on whether the aerial obscures vision so I assume it is all OK. BM52
Post #207586 2nd Feb 2013 1:25pm
WelshGas
I fitted my Kenwood DAB aerial a little higher than recommended, about 10cm from top, and have excellent reception all over S.Wales. Thumbs Up LANDYWATCH
Post #208431 4th Feb 2013 9:44pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
A quick pic of the JVC HAL-2 aerial mounted on the wing...
It has both FM and DAB outputs. http://www.yorkshireoffroadclub.net/
Post #208449 4th Feb 2013 10:20pm
bm52
I thought about Hal 2 but I like the normal aerial as I use it like a cats whisker for car parks etc. Comes in quite handy. BM52
Post #208461 4th Feb 2013 10:57pm
WelshGas
Too true bm25. Rolling with laughter LANDYWATCH
Post #209294 7th Feb 2013 7:43pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
It is my 90 in davew's pic above.
With the cage and lift and hd springs I don't even think about going in multistorey or overhead barriered car parks! Whistle Shocked Thumbs Up Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #209897 9th Feb 2013 6:31pm
Cheshire110
davew wrote:
I fitted a roof mount aerial on the wing in place of the factory one. It's a combined DAB and FM aerial, works really well and is flexible. On my Range Rover I used a stick on type but there's a lot more glass in that !
This is the one I used on the 90 wing...
http://www.dabonwheels.co.uk/JVC_HAL-2__DAB_car_aerial.html
Hey guys, just wondering if anyone had any tips to give.
I too have bought the same roof/wing mount DAB+FM aerial and aren't getting great signal. Suspect it could be an earth issue?
Did you sand down the underside of the wing for better contact? Or use tinfoil etc as it mentions? Does it matter that the wing is aluminium etc? Cheers, David
Post #624311 15th May 2017 12:39pm
DAZ110
I used this splitter fitted using the standard aerial and it works great around here in kent:
http://www.dabonwheels.co.uk/Kinetic_DAA-7...itter.html
Post #624352 15th May 2017 4:22pm
Page 2 of 2 <12
