![]() | Home > Puma (Tdci) > Thrust Bearing or ? ...tickover rattle on Puma |
Yes its the clutch release bearing
![]() mine is on its way out as well ![]() as been for a bit now ![]() |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Mine rattles too.
Some times its fine. Still drives fine though Will have to change it when the warm weather comes ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Had mine replaced under warranty
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Had it on mine when I picked it up, I and the dealer thought it was the thrust bearing, when they removed the box they found one of the anti rattle springs on the clutch plate had broken. The dealer i brought the car from was not local, my local dealer was great in doing the warranty work with the items i found after having it a week, they even did extra work they noted too
![]() This was on an 11 plate with 8k, done 4k since and it's been fine since........... Darren |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I also had the annoying rattle at tickover, turned out to be the springs in the clutch plate had lost their springiness. Replacement clutch under warranty, but I did leave it for about 6 months before taking it in without any issues bar the rattle.
