Home > Puma (Tdci) > Removing air filter housing
CapeLandy
South Africa
I wanted to remove mine to check again the play in my steering box-links-arm and the manual says to remove the aircon compressor/gas etc - WTF Shocked
I can't see the exact reason nor can I see the bolt heads to remove the filter box.
The manual drawing isn't exactly very helpfull.
Anyone taken theirs out yet?
Post #20881 29th Dec 2009 1:43pm
ponamore
United Kingdom 2015 Defender 110 Puma 2.2 USW Tonga Green
Filter box is held in with four pop rivets look under wheel arch you will see four large pop rivet heads this will release air filter housing.
Post #20885 29th Dec 2009 4:11pm
CapeLandy
South Africa
Thanks
I did notice some 6mm bolts in the wheel arch. Could these be in place of rivet heads and release the filter box?
Post #20903 30th Dec 2009 5:28am
ponamore
Mine where rivets 4 of them directly below filter, i drilled these out then just pulled free from rubber grommets, all i needed to do was release to enable me to fit snorkel and seal all joints making them water proof, not a nice job, to remove completely you will have to remove viscus fan guard and pipe directly above air box, all the best.
Post #20907 30th Dec 2009 8:22am
CapeLandy
South Africa
The only pipe running above the airbox is my aircon pipe Shocked
Think I am going to leave it there after all and get LandRover to Embarassed sort the steering knock at February Service.
Post #20915 30th Dec 2009 10:40am
