Home > Puma (Tdci) > Removing air filter housing |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I wanted to remove mine to check again the play in my steering box-links-arm and the manual says to remove the aircon compressor/gas etc - WTF
I can't see the exact reason nor can I see the bolt heads to remove the filter box. The manual drawing isn't exactly very helpfull. Anyone taken theirs out yet? |
29th Dec 2009 1:43pm |
Thanks
I did notice some 6mm bolts in the wheel arch. Could these be in place of rivet heads and release the filter box? |
30th Dec 2009 5:28am |
ponamore Member Since: 15 Nov 2009 Location: ludlow Posts: 44 |
Mine where rivets 4 of them directly below filter, i drilled these out then just pulled free from rubber grommets, all i needed to do was release to enable me to fit snorkel and seal all joints making them water proof, not a nice job, to remove completely you will have to remove viscus fan guard and pipe directly above air box, all the best.
30th Dec 2009 8:22am |
The only pipe running above the airbox is my aircon pipe
Think I am going to leave it there after all and get LandRover to sort the steering knock at February Service. |
30th Dec 2009 10:40am |
