Home > Puma (Tdci) > back to basics
Caterham
back to basics
sorry ....same old again.
to me this is obvious (obviously wrong that is) but I'm not a hardened / experienced landy owner so please bear with me.
removing the differences you'd expect between and warm and cold engine if you were to pull off and leave the revs at say 2000 rpm in 1st gear I presume you'd expect to hear the same noise each (assuming flat road / load on engine) ?
yes / no / may be ?
Post #200796 11th Jan 2013 11:52am
JeremyJ
If I understand the question right, then yes I would expect the same noise if on the same road, same gear, same engine load, same temperature each time!
Post #200802 11th Jan 2013 12:07pm
MartinK
My diesels are much noisier when cold...lots of clatter till they get up to temperature (Volvo D5 and Puma)...
Better in summer, worse in winter
When warm, no difference... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #200812 11th Jan 2013 12:38pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
hmmmm, dont know
As the ECU is measuring barometric pressure, and air temp i suppose its doing something with it, eg adapting fuel mapping, turbo ? sure the mappers can enlighten us.
Another thing is the drive by wire accelerator, is it self-learning? probably not but eg my merc learns my driving style and adapts to it (so from lazy to sporty behaviour depending on how fast and deep i press the gas pedal, then its adapting this till it sees i am canceling the input faster than expected and will tune down the temper again)
just mentioning, but generally the answer to your question should be yes i guess
Post #200816 11th Jan 2013 12:50pm
Delskinz
England 2007 Defender 110 Puma 2.4 SW Tonga Green
"you'd expect to hear the same noise each?"
Not sure of the question? Are you asking the noise from the engine or gearbox/drivetrain and engine?
If the air conditions, engine conditions and fuel conditions are the same each run then yes it would make the same sound. But as previously stated there are so many variables - air temperature, air density, air moisture, engine temps, exhaust temps etc etc there will always be differences. Plus unless you recorded each run the sound would be difficult to differentiate between (your ear's play tricks).
Post #200835 11th Jan 2013 2:35pm
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
Worth checking to see if your engine lifting eye bracket isn't loose. Mine made a terrible rattling sound on start up. Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
Post #201106 12th Jan 2013 3:33pm
Caterham
well - should get it back tomorrow.......
can't wait.
to see what goes wrong this time Neutral
Post #208298 4th Feb 2013 2:03pm
Happyoldgit
Sorry but I've lost count, what are they supposed to have done this time? Steve.
http://forums.lr4x4.com
Post #208309 4th Feb 2013 3:03pm
Caterham
haven't the faintest idea - lost track myself.
I just go in swap cars and then go back again a week or two latter and swap back again Shocked
got a westminster FFRR loads of toys ...... but horrible car to drive (at least I think so)
oil out of of the gearbox extention piece - swapping seal again ?
Post #208312 4th Feb 2013 3:13pm
roamingman
Cosh you are lucky, had a D3 just gone back end of lease, on the dealers up her you don't even get a LR let alone a FFRR. Sad Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #208345 4th Feb 2013 5:29pm
Caterham
The FFRR is off enterprise via LR and not one of the dealers....
any how would appear they're getting ready to dismantle the tranfer box for the 4th time !!!
its leaking oil but no one seems to know from where. LR technical guy is turning up for the 3rd time ......
just hope they get it all back together before the warranty runs out cos I'm worried they'll leave me to put it back together and charge me storeage if I don't hurry up.
should know more later but suspect its going to be a new g box and hopefully transfer box too !
Sad
Post #209205 7th Feb 2013 3:37pm
