Home > Puma (Tdci) > back to basics |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
sorry ....same old again.
to me this is obvious (obviously wrong that is) but I'm not a hardened / experienced landy owner so please bear with me. removing the differences you'd expect between and warm and cold engine if you were to pull off and leave the revs at say 2000 rpm in 1st gear I presume you'd expect to hear the same noise each (assuming flat road / load on engine) ? yes / no / may be ? |
11th Jan 2013 11:52am |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
If I understand the question right, then yes I would expect the same noise if on the same road, same gear, same engine load, same temperature each time!
11th Jan 2013 12:07pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
My diesels are much noisier when cold...lots of clatter till they get up to temperature (Volvo D5 and Puma)...
Better in summer, worse in winter When warm, no difference... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
11th Jan 2013 12:38pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
hmmmm, dont know
As the ECU is measuring barometric pressure, and air temp i suppose its doing something with it, eg adapting fuel mapping, turbo ? sure the mappers can enlighten us. Another thing is the drive by wire accelerator, is it self-learning? probably not but eg my merc learns my driving style and adapts to it (so from lazy to sporty behaviour depending on how fast and deep i press the gas pedal, then its adapting this till it sees i am canceling the input faster than expected and will tune down the temper again) just mentioning, but generally the answer to your question should be yes i guess |
11th Jan 2013 12:50pm |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 |
Worth checking to see if your engine lifting eye bracket isn't loose. Mine made a terrible rattling sound on start up. Pimped black '07 Puma
Equally Pimped Black Pick up Truck Rollin deep |
12th Jan 2013 3:33pm |
well - should get it back tomorrow.......
can't wait. to see what goes wrong this time |
4th Feb 2013 2:03pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Sorry but I've lost count, what are they supposed to have done this time? Steve.
4th Feb 2013 3:03pm |
haven't the faintest idea - lost track myself.
I just go in swap cars and then go back again a week or two latter and swap back again got a westminster FFRR loads of toys ...... but horrible car to drive (at least I think so) oil out of of the gearbox extention piece - swapping seal again ? |
4th Feb 2013 3:13pm |
roamingman Member Since: 15 Mar 2012 Location: nearly thier Posts: 152 |
Cosh you are lucky, had a D3 just gone back end of lease, on the dealers up her you don't even get a LR let alone a FFRR. Live Life Ti'l You Die Teddys are out thier http://teddybearspicnic.webs.com http://130sasha.co.uk/ |
4th Feb 2013 5:29pm |
The FFRR is off enterprise via LR and not one of the dealers....
any how would appear they're getting ready to dismantle the tranfer box for the 4th time !!! its leaking oil but no one seems to know from where. LR technical guy is turning up for the 3rd time ...... just hope they get it all back together before the warranty runs out cos I'm worried they'll leave me to put it back together and charge me storeage if I don't hurry up. should know more later but suspect its going to be a new g box and hopefully transfer box too ! |
7th Feb 2013 3:37pm |
