Home > Technical > Quick question for Killer or GoBeyond |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
you can either take the whole dash cluster out by uncliping the wiring harness on the back, or you can remove the black peice which is again just clipped in place, as i did on mine you know the walnut bit on mine- is this what your talking about CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
2nd Feb 2013 7:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Yep, that bit Chris. Not much point in taking the lot out but that bit can just be taken out on it's own rings fitted then positioned back in place right? $W33T $0U7H3RN $UG4R
2nd Feb 2013 7:59pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Correct Steve
2nd Feb 2013 8:02pm |
Great. Just thought it would be much easier cleaner and less likely to get damaged that way. Much easier on a flat surface than with the wheel in the way and at an angle. $W33T $0U7H3RN $UG4R
2nd Feb 2013 8:04pm |
