Home > Technical > Quick question for Killer or GoBeyond
You know the part of the dash that the dial rings clip into? Does that easily come right out of the vehicle so that I could just clip my dial rings back in somewhere easier rather than in place. Would make things so much easier. Just asking because I cannot honestly remember now. I think it does.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #207731 2nd Feb 2013 6:49pm
Killer90
Site Sponsor
you can either take the whole dash cluster out by uncliping the wiring harness on the back, or you can remove the black peice which is again just clipped in place, as i did on mine you know the walnut bit on mine- is this what your talking about Question Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #207746 2nd Feb 2013 7:27pm
Yep, that bit Chris. Not much point in taking the lot out but that bit can just be taken out on it's own rings fitted then positioned back in place right? Thumbs Up $W33T $0U7H3RN $UG4R
Post #207770 2nd Feb 2013 7:59pm
Correct Steve Thumbs Up
Post #207772 2nd Feb 2013 8:02pm
Great. Mr. Green Just thought it would be much easier cleaner and less likely to get damaged that way. Much easier on a flat surface than with the wheel in the way and at an angle. $W33T $0U7H3RN $UG4R
Post #207775 2nd Feb 2013 8:04pm
