Home > Puma (Tdci) > Fitted my NAS today...
Page 3 of 3 <123
TJ101
XS Pete wrote:
Quote:
but as it was too high for the trailers i tow, and needed an adjustable slider towbar,, it had to go
Why not just put your slider on the NAS? That's what I did over a year ago and have had no problems with that set up Thumbs Up
Pete
No support to the bottom of the slider,, unless you make up some stays to go back up to the rear of the chassis
Same as people who fit drop plates Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #207572 2nd Feb 2013 11:41am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I considered that at the time. The problem obviously is that the pick up ponts on the chassis you need to use are already occupied by the lower supports for the step, and you can't have both. I was going to try and fabricate something to serve both purposes, but thought I'd just try it in the mean time.
15 months on I still haven't got around to making something, but have used it as is a lot and not had any problems. The maximum I've towed in that period is under 2000Kg, but I dare say if you needed to tow more, it would probably be worth attending to.
Pete
Post #207574 2nd Feb 2013 11:57am
XS Pete
Don't know why I never noticed this before. On the Dixon Bate instruction sheet, it says, 'in this configuration (meaning fitted without the braces) the towing capacity is limited to 3500Kg. To increase the towing capacity to 5000Kg use bracing struts (not supplied) fastened between the lowest holes on item DB67922 (the slider frame bit) and the vehicle chassis'.
So that reads to me that the lower braces aren't required unless you need huge towing capacity Thumbs Up
Pete
Post #207576 2nd Feb 2013 12:14pm
defender75 wrote:
What the story with the bumper on the xtech. It looks different.
It is - it's shorter so fits inboard of the ends of the rear crossmember. Not sure why this is; could be so that the end holes in the crossmember are available to fit other items such as bumperettes?
Post #208851 6th Feb 2013 12:02pm
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Does this style bumper give you more ground clearance then the standard LR towbar? its only a car!
Post #209615 8th Feb 2013 7:51pm
TJ101
Pete
Was talking to a fellow 110 owner Very Happy , at the weekend, he had a slider on a Nas style bar,, and the step bar bent under towing !! He has fitted a normal tow bracket now California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #210385 11th Feb 2013 1:06pm
XS Pete
That's not the first one I've heard of getting bent either. I don't really understand how it happens though. If fitted as per the instructions, with the lower supports and the proper grade bolts, there are so many fastening points spreading the load across the whole cross member, underneath it with the angle bracket in the centre, and the two lower supports running back to the chassis, it must be stronger than a standard towbar.
Maybe it's the welds which break, or some other failure mode such as fatigue cracking caused by something repeatedly flexing, through not being torqued up properly, I don't really know. It would be interesting to see one which has failed.
Pete
Post #210584 11th Feb 2013 8:50pm
Pete
Agree - especially if people could post any photos of said failures and see if there are any particular issues that can be pre-emptively addressed.
Post #210657 12th Feb 2013 8:47am
Stevelandy
England 2012 Defender 110 Puma 2.2 CSW Firenze Red
Xs pete could you or anyone else post a picture of the adjustable
Dixon bate fitted to a lr nas and part number , as I need to get down to
About 450mm thanks
Post #238093 23rd May 2013 6:13pm
Page 3 of 3 <123
