Home > Puma (Tdci) > JW Speaker 8700 LED Lamps MOT Failure |
why the 8700 failed? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Feb 2013 4:16pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
My old (59 plate) past so you need to find out why are they to high etc etc
They are fully compliant so who tested it ? |
1st Feb 2013 4:31pm |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 |
I have just received the paper work;
001 NSF Headlamp aim to high [1.8].... okay, I can adjust this.... although I never get flashed by oncoming vehicles. 002 OSF Headlamp aim beam image obviously incorrect. [1.8.A.2] I have a drawing showing the pattern, apparently my headlamps show () () and it should look like this |____ There is some condensation in the OSF lamp glass but I never thought it would ruin the beam. Paul Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Me too, and a unopened pm on here from before Christmas.
Exactly my problem, but in both lights. So much so its starting to run down the inside of the lens. |
1st Feb 2013 5:04pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Ive had mine 3 years no problems seems a bit of a jobsworth how long does it take to adjust a lamp , i always find independent MOT Stations more helpfull
1st Feb 2013 5:07pm |
What else apart from the lights did it fail on? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Feb 2013 5:11pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 712 |
I've had mine mot'd no problem at all, in fact the mot guy commented on how good the beam pattern was.
1st Feb 2013 6:18pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Can't comment on the problem you're having but I do know that Tim from Mobile Centre has been very poorly since before Christmas and is only now starting to deal with enquiries from his sick bed, I'm sure he'll be back to you very shortly
1st Feb 2013 6:28pm |
Who fitted the headlights and did they fit them correctly and align them?
1st Feb 2013 6:31pm |
When I fitted mine myself I just took the old ones out and fitted the JWS without moving the adjusters and they were spot on MOT time.
1st Feb 2013 6:48pm |
Thanks for all replies, sorry that Tim is not so well. Hope he's back fit asap.
MOT failed usual stuff, rear shocker bushes and wiper blades. Bushes can be done before warranty expires in two weeks. I fitted the lamps myself, it's a straight forward replacement job and then took them over to a mate that run's his own MOT business and he tested them, he advised they were some of the best lamps he had seen. Very clean cut off and ultra bright. So for them fail an MOT just two years later was a bit alarming. I will replace them with the old units to get a pass and will try Tim to see about warranty replacement. As my 110 is nearly out of warranty I decided it was best to let the stealer do the MOT, and pick up any warranty jobs. Typical they fail lights that are aftermarket and the best upgrade you can put on your vehicle in my opinion. |
1st Feb 2013 7:07pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
The Speaker 8700 are fully road legal in the UK.
It appears that the MOT failed the headlights on their aim rather then on them being not OEM. Our 110 has passed its MOT with the 8700 fitted no problem. Condensation in LED lights can occur. They are typically fitted with a Goretex type filter. This allows the light unit to breathe. Given the correct weather conditions the lights should dry themselves out. Brendan |
1st Feb 2013 8:01pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
You don't say why the lights were failed... or did I miss that bit ???
I'm assuming it wasn't alignment as changing them won't fix that. http://www.yorkshireoffroadclub.net/ |
1st Feb 2013 10:14pm |
Yes you missed it! One was alignment the other beam pattern.... In a nutshell..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 1st Feb 2013 10:24pm. Edited 1 time in total |
1st Feb 2013 10:23pm |
