Home > Puma (Tdci) > Fitted my NAS today... |
Bit off topic but that explains what the strips of steel that was making it damn near impossible for me to get a spanner or even a nut into the end of the cross member to fix my rear bumperettes, It was the tab for locating the anti-crush tubes.
28th Jan 2013 2:23pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Mine were a little loose too when the dealership first fitted the step. I had to make up a special tool to be able to get at the inner ones on the ends and successfully torque them up. No movement since though.
Pete |
28th Jan 2013 2:48pm |
Thanks - might need to loosen them off and re-torque to the settings in the instructions.
28th Jan 2013 3:00pm |
Mackers-a Member Since: 16 Dec 2012 Location: Torquay Posts: 24 |
Hi Guys I'm after one of these rear steps too. Just to clarify I think its the UK version STC50269AA, with 4 hole tow bar mounting plate.
I'm interested if anyone has any experience as to which manufacturers make these and what the quality is like? If possible I would also like to support one of the site sponsors when I order. Many thanks |
29th Jan 2013 10:14pm |
Mine's a genuine lr part - there are two different part numbers for 90 VPLDP0095 or 110 VPLDP0096.
30th Jan 2013 2:27am |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hello,
mine is genuine. I did put one slice (rondelle in french ) because I did not want to see the frame crushed Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
30th Jan 2013 8:01am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
What is the difference between the two. I have just bought one (LR Part) and want to fit it to a 90. What if its off of a 110? Thanks "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
1st Feb 2013 7:32am |
The bracing bars are different to accommodate the differences in the rear chassis. If the one you've bought is off a 110 then it won't fit properly. Darren
1st Feb 2013 7:41am |
Thank you.
What bracing bars do you mean? (the almost Z shaped bars that attaches to the chassis that run front to back?) If that makes sense .... "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
1st Feb 2013 7:44am |
These bracing bars:
1st Feb 2013 11:16am |
Ok thats what I thought. Thank you very much. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
1st Feb 2013 11:17am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Had a step tow bar on previous Defenders,
but as it was too high for the trailers i tow, and needed an adjustable slider towbar,, it had to go California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
1st Feb 2013 7:06pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
What the story with the bumper on the xtech. It looks different.
2nd Feb 2013 5:19am |
Why not just put your slider on the NAS? That's what I did over a year ago and have had no problems with that set up Pete |
2nd Feb 2013 10:32am |
