Home > Puma (Tdci) > Fitted my NAS today...
Page 2 of 3 <123>
Glynparry25
The reason the step is different is because the NAS step technically isn't legal in Europe due to in not being Type approved. Hence why they do it with holes for the tow bar with a shiny sticker on the back stating it type approved.
Glyn Dog Sheep
Post #206245 28th Jan 2013 2:20pm
JWL
Bit off topic but that explains what the strips of steel that was making it damn near impossible for me to get a spanner or even a nut into the end of the cross member to fix my rear bumperettes, It was the tab for locating the anti-crush tubes. Thumbs Up
Post #206247 28th Jan 2013 2:23pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine were a little loose too when the dealership first fitted the step. I had to make up a special tool to be able to get at the inner ones on the ends and successfully torque them up. No movement since though.
Pete
Post #206251 28th Jan 2013 2:48pm
Thanks - might need to loosen them off and re-torque to the settings in the instructions.
Post #206252 28th Jan 2013 3:00pm
Mackers-a
Hi Guys I'm after one of these rear steps too. Just to clarify I think its the UK version STC50269AA, with 4 hole tow bar mounting plate.
I'm interested if anyone has any experience as to which manufacturers make these and what the quality is like? If possible I would also like to support one of the site sponsors when I order.
Many thanks
Post #206684 29th Jan 2013 10:14pm
Mine's a genuine lr part - there are two different part numbers for 90 VPLDP0095 or 110 VPLDP0096.
Post #206713 30th Jan 2013 2:27am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hello,
mine is genuine.
I did put one slice (rondelle in french ) because I did not want to see the frame crushed
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #206734 30th Jan 2013 8:01am
BruceT
South Africa
What is the difference between the two. I have just bought one (LR Part) and want to fit it to a 90. What if its off of a 110?
Thanks "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #207258 1st Feb 2013 7:32am
The bracing bars are different to accommodate the differences in the rear chassis. If the one you've bought is off a 110 then it won't fit properly. Darren
Post #207259 1st Feb 2013 7:41am
BruceT
South Africa
Thank you.
What bracing bars do you mean? (the almost Z shaped bars that attaches to the chassis that run front to back?)
If that makes sense Laughing .... "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #207260 1st Feb 2013 7:44am
These bracing bars:
Post #207294 1st Feb 2013 11:16am
BruceT
South Africa
Ok thats what I thought. Thank you very much. Very Happy "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #207295 1st Feb 2013 11:17am
TJ101
Had a step tow bar on previous Defenders,
but as it was too high for the trailers i tow, and needed an adjustable slider towbar,, it had to go Sad California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #207435 1st Feb 2013 7:06pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
What the story with the bumper on the xtech. It looks different.
Post #207517 2nd Feb 2013 5:19am
XS Pete
Why not just put your slider on the NAS? That's what I did over a year ago and have had no problems with that set up Thumbs Up
Pete
Post #207565 2nd Feb 2013 10:32am
Page 2 of 3 <123>
