Home > Puma (Tdci) > Tow Bar
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Tow Bar
Is a Puma tow bar the same as an earlier Td5 model. The reason I ask is that on the Td5 I have it's a fully adjustable slider type but on my Puma it's fixed and I wanted to swop them around..Looked on Ebay and they seem to be sold as two different types Confused ..Many thanks in advance. 04' 90 Td5 CSW..
Post #204795 23rd Jan 2013 8:13pm
bell-auto-services
I think the diagonal stays are different, from memory the puma chassis has welded brackets on it at the rear about 12" in from the back to which the diagonal supports bolt and the TD5 does not as they bolt directly through the chassis and so have longer diagnoal bars.
I may be wrong but I have had some fitting issues in the past that are at the back of my mind. that said im sure it was a simple fix.
Pete
Post #204802 23rd Jan 2013 8:43pm
According to all the part numbers I can find, it's the same from '98 onwards. As an example, THIS ONE ON EBAY is advertised for a tdci but the description says from '98 (TD5) onwards.
Edit: I've just realised that you're talking about 90's, which may be different to 110's Rolling Eyes Darren
Post #204804 23rd Jan 2013 8:56pm
