Home > Puma (Tdci) > Wiper issue......
leonski
Wiper issue......
Can any one tell me if this is easily curable!...but I think I already know the answer...
Wipers have decide to extend their ark and run from edge to edge.....most of the time, but not all...
Snow slid of the roof when they were in action and I can't decide if this has caused it, or if it is a coincidence.
The wiper mech was replaced under warranty last year, but the vehicle is now out of warranty by a month, so I was wondering if it is something that is fairly simple to tackle myself.
Cheers,
Leon.
Post #204437 22nd Jan 2013 7:29pm
BruceT
South Africa
sounds like they could have jumped a tooth. Try loosing the wiper bolt and adjusting them. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #204622 23rd Jan 2013 10:35am
If they had jumped a tooth they would still wipe the same angle of arc, but would hit the frame at one end or the other. If the arc has increased (which it what the OP suggests) then I think that either the drive cable (rack) has stretched, or the wheelboxes have deformed, or the drive pin on the motor/cable link has come loose.
If it is the drive pin or cable it is realtively easy to sort and doesn't require the full removal of the dash (the motor and rack can be removed with the dash loosened but in situ - I posted a "how to" some while ago). A dealer will probably remove the dash for this however.
If the wheelboxes require removal then unfortunately the dash must come out, which makes it quite a big job.
Post #204674 23rd Jan 2013 12:30pm
leonski
Many thanks!
i am hoping that it is just the drive cable...I can't believe that such a small amount of snow could do what it has done!
...would you be able to send me the how to link...as I can't find it!
Cheers for your help,
Leon.
Post #204698 23rd Jan 2013 1:05pm
