Home > Puma (Tdci) > Webasto on a Puma can it be done?
Page 2 of 2 <12
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
Thanks for posting the pics.... Completely forgot about the LH / RH differences. Obviously mine is LHD.
Engine bay: I used Tectyl Protective Products... Mainly Tectyl Amber on all metal parts and Tectyl 930 Motor Konservering on rubber / plastic parts. The latter is not designed for that but I made good experience with it. After a year or two you give the engine bay a good wash (hot / high pressured water) and then apply the same products again. Everything will shine as if it was new...
Regards
George The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #20431 18th Dec 2009 6:00pm
bjartin
Norway
According to the Norwegian price list all models come with Webasto heater w / timer for pre-heating.
MODELLER Regavg. S SE 90 Soft Top
TD4 2,4 122HK/90 kw 2 seter varebil 75 910 314 600
TD4 2,4 122HK/90 kw 4 seter personbil 330 206 592 000 606 900
Prisene inneholder CO2 kompensasjon for 75.000km i samarbeid med Climate Care.
STANDARD- OG EKSTRAUTSTYR S SE 90 Soft Top
6-trinns manuell girkasse S S S
Diesel Webasto kjørevarmer m/tidsur for forvarming S S S
El.startsperre med alarm S S S
Elektrisk oppvarmede seter foran og frontrute S S S
Høy- og lavgir S S S
Konstant 4x4 med senter-diff.sperre S S S
Post #20501 20th Dec 2009 1:52pm
hornet
Re: Webasto on a Puma can it be done?
[quote="Chuggaboom"]I'm thinking of having a Webasto Thermo Top C fitted but some say it can be done, some say it can't.
Anyone done it????[/quote]
Found a good solution apart from the solution above the turbo (quite common) in the German forum Blacklandy, link to the picture of the construction is here: http://blacklandy.de/blboard/forum/showthr...amp;page=7
He mounted it behind the right front light under the air-filterbox..
HTH!
Post #21214 4th Jan 2010 3:48pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
hornet
any chance of posting the pics on here - the German registration process has defeated me!
Post #21227 4th Jan 2010 7:53pm
BigGeorge
Cobs
you've got mail...
Thanks & Regards
Post #21375 6th Jan 2010 7:48am
cobs
Here they are -courtesy of George
seems as though this is a new fitting kit to mount the webasto under the front wing - here's link to the site and some pics:
http://www.entreq.de/ersatzteile_shop,Defe...4,eng.html
Post #21421 6th Jan 2010 6:07pm
roel
Off Topic Hello George,
I noticed you live in Zurich. I am currently working in Zurich on a drilling rig in a building project near the Triemlistrasse/Birmensdorferstrasse. So if you see a Dutch G4 D3 driving through town it's me.
I never worked that close to a city centre. Oh and if you live close Sorry for the noise we try to be quiet during the night. Roel
2003 90 Td5 (2009-now)
Post #21435 6th Jan 2010 7:39pm
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi!
Do you know if this bracket is still available? Does it easy to install and compatible with the new webasto thermo top Evo?
Best regards
Post #874897 28th Dec 2020 10:14am
jst
thats a really long coolant hose run to there assuming you plumbing into the heater hoses at 19mm ID? i looked at that position and decided it was too far/awkward for coolant pipes.
better position is above passenger seat box beside the heater blower RHD vehicle. Some pics of my installation on here somewhere. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874910 28th Dec 2020 1:37pm
jst
https://www.defender2.net/forum/topic75720-15.html Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874912 28th Dec 2020 1:47pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
https://entreq.de/produkte/wasserstandheiz...top-evo-5/
Looks like they do a kit but from my shoddy German think it’s only installable by them. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #874920 28th Dec 2020 2:26pm
Page 2 of 2 <12
