Home > Puma (Tdci) > Air Con upgrade?
Page 2 of 3 <123>
BruceT
South Africa
Regard wrote:
Seems like most things on a Puma was developed for English summers......
Intercooler
A/C
Radiator...... Whistle
hehe true. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #202935 18th Jan 2013 1:07pm
pannawonica
Australia
I actually beleive the aircon problem is twofold. First the aircon is from a small saloon type car Kia I think, not enough capacity. The second issue is the aluminium floor, aluminium conducts heat from the road, exhaust and tranny far better than steel. Big Cry
Post #203218 19th Jan 2013 2:01am
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
On my utility I have segregated the passenger cell and the load area with a thermal curtain which sits on the load/dog guard. At least then what precious cold air that there is is used to cool me and not a bunch of tools/boxes in the back. This roughly halves the volume to be cooled. For this I bought a £20 black roller blind with a metallised inner layer and then cut to size, added some velcro attachment points and then i put it in place. Going to the Sahara in a few months so I will get it out of the box as i never need to use it in the UK. Laughing
Other things that you could do is to mount a board or cover the roof rack (ie maxtrax or RTT) over the passenger cell to stop the direct heat of the sun beating on the roof (ie it is shaded). Won't do anything for ambient temp but every little helps.
Post #203262 19th Jan 2013 10:15am
SteveS
Aluminium is a better conductor true but this really relates to the ease with which heat is transmitted quickly from point A to point B. So Alli will heat up (and cool down) quicker than steel but both will get to local ambient at some point. Whether steel or alli, insulation is what is needed - something that distances the hot from the cold - air bubbles (closed cell foam), layers, fibres, plastics etc or reflects the hot or cold away - matallized polyester, foil, etc.
Post #203265 19th Jan 2013 10:24am
mk1collector
Insulate behind the trim, roof lining and carpet and seal the factory fitted gaps in the panels and you should stay a lot cooler as the suns heat won't get in as much and your air conditioned air won't get out as much. Thumbs Up
Post #203267 19th Jan 2013 10:24am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
So no-one has tried to fit a larger compressor?
Post #203774 21st Jan 2013 7:01am
Naks
Hmm, I doubt you'll find the space, the engine bay is very cramped as it is --
Post #203775 21st Jan 2013 7:02am
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Re: Air Con upgrade?
Naks wrote:
heinrichnel wrote:
Anyone knows if there is something I can do to upgrade the aircon? She wants me to trade the 110 for a Disco 4! I don't really want to do it!
Put your foot down and tell her Africa is not for sissies Rolling with laughter
On a more serious note, do a decat, which will alleviate the cabin heating up, and do an air-con regas?
I put my missus on the back of a motorbike for a trip into the Karoo (over 40c wearing bike gear) who needs air con. Rolling with laughter
On a serious note my air con wasn't great until I had a regas but it's much better now. Thumbs Up
Post #204062 21st Jan 2013 8:47pm
AndyS
Tinted windows is said to help a lot, as does duct-taping up all the gaps in the front bulkhead, stops hot air leaking in through gaps.
Post #204089 21st Jan 2013 9:18pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Different system I know, but I was in Spain this summer at +42c I have been in this type of temp before and the A/C was not great however this year I had insulated the floor and seat box and on top of my tinted rear windows I fitted insulated blinds this year.
It made a massive difference and helped the A/C cope as most of the cab heat is generated from the floor and not from the outside.
Since then I have insulated the rest of the truck and judging by the heat it now retains then I hope it will make a huge difference.
Regards, Jason.
Post #204160 21st Jan 2013 11:38pm
BruceT
South Africa
lol@yobbie
How did you insulate your truck?
I have tinted windows and although i dont feel i have a major problem there is always room for improvement. I suppose i am still used to traveling in a TD5 where my knees were nice and cool.... Laughing
Thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #204170 22nd Jan 2013 5:37am
mk1collector
Closed cell foam behind all the trim and seal all the seams you can.
Post #204239 22nd Jan 2013 10:18am
jasong4110
BruceT wrote:
lol@yobbie
Thank you.
Two layers of closed cell foam taped with foil tape:
Jason.
Post #204304 22nd Jan 2013 1:18pm
BruceT
South Africa
Jeez, thats awesome......I probably wont go that far but would be keen on doing the front half of the truck.
Your truck must also be quieter?
What product did you use? "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #204313 22nd Jan 2013 1:28pm
jasong4110
I had only done the front of the truck for our Spain trip this year it did make a huge difference I hadn't done inside the seat boxes at that point and you could feel the difference between the floor and the seat box.
I have now insulated inside both seat boxes and it has made a big difference, sound wise it has made a massive difference, I didn't think my truck was that bad but realised how much better it can be, I can have a conversation without raised voices at 70mph.
For the insulation I used http://www.ebay.co.uk/itm/MILITARY-LAND-RO...4ac0886242 two and a half kits so cost me around £45 including the tape.
Jason.
Post #204325 22nd Jan 2013 1:39pm
Page 2 of 3 <123>
