Home > Maintenance & Modifications > Sound Proofing/Insulation best options?
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
Hi All,
On-going project now requires a nicer interior so going to start with sound proofing/insulation.
What is the best option for a 90 CSW front and back.. Front I don't have a standard gearbox layout, my shifter is pretty much next to my seat and the rear has a gun safe built in to the bulkhead so the rear tub area is a little shorter than standard.
Needs to be waterproof and not too much of a pain to fit.. most like have mats over the top afterwards..
Nick
Post #203821 21st Jan 2013 1:09pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
loads of threads on this subject, some very recent ones as well.
Dynamat seems favorite at the moment, but there are other options BM52
Post #203822 21st Jan 2013 1:19pm
MartinK
The quickest benefit I saw was NoiseKiller in the rear tub. Especially on wet roads, the spray noise from the rear wheelarches was very noisy. A noisekiller kit will/did cut 90% of this out.
Since then I have bought the noisekiller kit to the front (seat boxes, footwells, and bulkhead). Not quite as pronounced an improvement, but did imporve things a bit.
One day I'll try Dynamat to the upper body in the rear, to reduce noise further, but so far I'm happy, can use the radio on lower volumes, and talk to passengers without shouting...makes long journeys soo much nicer Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #203825 21st Jan 2013 1:33pm
bm52
@martink - i did the same, full NK kit. Makes a big difference and the tour around France quite quiet for a Defender BM52
Post #203830 21st Jan 2013 1:59pm
MartinK
And although this won't help with a V8.... DGARDEL was looking at installing a 2.2 tdci engine acoustic cover on a 2.4 ...expected to make a good difference but as yet untested Whistle Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #203856 21st Jan 2013 4:03pm
CarAudioSecurity seem to have some good deals on sound proofing kit ...
http://caraudiosecurity.com/shop/search_re...=0&y=0
Post #203919 21st Jan 2013 6:04pm
There is a bulk buy on this forum with cheaper prices on Dynamat ...
Post #203921 21st Jan 2013 6:07pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
I've used the whole NK kit available and it worked for me, less road, engine noise and I can talk to the person next to me. May be worth seeing if you have anyone close who have used other options and see, well hear the difference? _______________________________
Puma Defender 90
Post #203922 21st Jan 2013 6:08pm
barbel jim
Dynamat all the way Very Happy It is waterproof so won't soak up any water (unlike open cell which is majority of the noisekiller kit) Very easy to fit, and works out about the same �����. There is a group buy option on here. You can also put on multi layers if necessary, and cover every pannel, unlike the kits, which cover most. Look in the ultimate ice thread, I've just done mine, and there's pictures of others.
Post #203923 21st Jan 2013 6:08pm
nickh90
Dynamat it is then...
So for those who have done a 90... what do I need and how much of it?
Assume I could or might eventually insulate everything, doors, roof, rear tub front cabin
Then assume I can use a normal rubber fitted matt set on top afterwards?
Nick
Post #204391 22nd Jan 2013 6:32pm
barbel jim
I have used 120 sq ft so far- Didn't do the roof as have full headlining , Just the doors left to do, which I estimate will be another 24 sq ft. Mine is a hard top though, so I have done the sides as well. Should estimate to do all your 90 will be about 120 sq ft. Think that works out about 3 of the bulk kits.(36 sq ft a pack). You want normal Dynamat, a heat gun and a small hard roller. I used waterproof aluminium tape on the seams, although you don't have too. You can just lay your mats on top, or use spray adhesive. The only problem with sticking them in, you can't get them out should you need too.
Clean metal with something like white spirit/meths cut mat to shape, peel of backing, and use the heat gun and roller to get it to stick like Censored to a blanket, and follow the contours. Start one side of the sheet and work your way slowly across and you'll have no air bubbles. Simples Thumbs Up
Post #204398 22nd Jan 2013 7:00pm
PM bigruss, he's just done most of his 110 utility using a combination of regular and lite
Post #204406 22nd Jan 2013 7:12pm
hippohead
United Kingdom 2004 Defender 90 Td5 HT Epsom Green
I've just done mine with silent coat and anthracite carpet
cost about �150 to do the roof / sides / Floor / wheel arches etc
Post #204453 22nd Jan 2013 8:50pm
pannawonica
Australia
Dynamat all the way, just done the floor and load area . Due to ill health I have put off doing the roof, and couple of other jobs. However the improvement already has been quite good. Very Happy Thumbs Up
Post #204841 24th Jan 2013 3:12am
