![]() | Home > Maintenance & Modifications > Sound Proofing/Insulation best options? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
loads of threads on this subject, some very recent ones as well.
Dynamat seems favorite at the moment, but there are other options BM52 |
The quickest benefit I saw was NoiseKiller in the rear tub. Especially on wet roads, the spray noise from the rear wheelarches was very noisy. A noisekiller kit will/did cut 90% of this out.
Since then I have bought the noisekiller kit to the front (seat boxes, footwells, and bulkhead). Not quite as pronounced an improvement, but did imporve things a bit. One day I'll try Dynamat to the upper body in the rear, to reduce noise further, but so far I'm happy, can use the radio on lower volumes, and talk to passengers without shouting...makes long journeys soo much nicer ![]() |
@martink - i did the same, full NK kit. Makes a big difference and the tour around France quite quiet for a Defender BM52
And although this won't help with a V8.... DGARDEL was looking at installing a 2.2 tdci engine acoustic cover on a 2.4 ...expected to make a good difference but as yet untested
CarAudioSecurity seem to have some good deals on sound proofing kit ...
http://caraudiosecurity.com/shop/search_re...=0&y=0 |
There is a bulk buy on this forum with cheaper prices on Dynamat ...
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
I've used the whole NK kit available and it worked for me, less road, engine noise and I can talk to the person next to me. May be worth seeing if you have anyone close who have used other options and see, well hear the difference? _______________________________
Puma Defender 90 |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
Dynamat all the way
nickh90 Member Since: 19 Oct 2009 Location: Nr Horsham Posts: 196 ![]() ![]() ![]() |
Dynamat it is then...
So for those who have done a 90... what do I need and how much of it? Assume I could or might eventually insulate everything, doors, roof, rear tub front cabin Then assume I can use a normal rubber fitted matt set on top afterwards? Cheers Nick |
I have used 120 sq ft so far- Didn't do the roof as have full headlining , Just the doors left to do, which I estimate will be another 24 sq ft. Mine is a hard top though, so I have done the sides as well. Should estimate to do all your 90 will be about 120 sq ft. Think that works out about 3 of the bulk kits.(36 sq ft a pack). You want normal Dynamat, a heat gun and a small hard roller. I used waterproof aluminium tape on the seams, although you don't have too. You can just lay your mats on top, or use spray adhesive. The only problem with sticking them in, you can't get them out should you need too.
Clean metal with something like white spirit/meths cut mat to shape, peel of backing, and use the heat gun and roller to get it to stick like ![]() ![]() |
PM bigruss, he's just done most of his 110 utility using a combination of regular and lite
hippohead Member Since: 24 Dec 2012 Location: N00bery Posts: 11 ![]() ![]() ![]() |
I've just done mine with silent coat and anthracite carpet
cost about £150 to do the roof / sides / Floor / wheel arches etc ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by hippohead on 24th Jan 2013 8:16am. Edited 1 time in total |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Dynamat all the way, just done the floor and load area . Due to ill health I have put off doing the roof, and couple of other jobs. However the improvement already has been quite good.
