Home > Maintenance & Modifications > Doors don't shut in cold weather. |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Spray your oil up inside the locks, not down. There are two pivots at play in the lock mechanism. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
13th Jan 2013 5:34pm |
Apologies for the link to another forum, but try this;
http://forum.landrovernet.com/content.php/...How-to-Fix Worked for my 110 and Discovery too |
13th Jan 2013 5:36pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
i tried everything on my td5 and it cured it for about a day best thing to do it properly is buy new genuine ones from land rover around about £60 a door latch, not too bad to change over and it will work first time CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
13th Jan 2013 5:43pm |
TRR Motorsport Member Since: 07 Oct 2010 Location: Leicestershire Posts: 115 |
Thanks for the link. internals of lock cleaned with BC & lubed with lithium grease. all sorted. "If it ain't sideways, you just ain't tryin'! |
21st Jan 2013 2:32pm |
Well done that man... glad to help you get it sorted.
21st Jan 2013 4:03pm |
get some silicone spray on the rubbers otherwise they won't open either
21st Jan 2013 4:44pm |
to right, especially with melting snow and freezing nighttime temperatures |
21st Jan 2013 4:47pm |
stuckinmud Member Since: 23 Jan 2013 Location: monmouthshire Posts: 7 |
had this problem on previous defenders one of which became so intolerable i decided to investigate. found the end plate of the striker plate was clashing with something in the lock mechanism causing it to pop open.
made thick striker plate shim from 3mm? aluminium using existing shim (pt No MWC3148) as a template. once fitted i never had the problem again! exercise caution when loosening the striker plate bolts (I cant remember if the nuts are captive) the shims are slotted so you dont need to remove the bolts completely. fitting multiple shims might be a better route but i was too impatient to wait for the post. borrowing the shims from other doors might confirm the solution before you spend time making thicker ones. May not be the solution to everyones problem but it certainly worked for me. i have tried to upload photo of damaged striker and shim in situ but as i am a newbie here i havent yet found the method of doing so. if anyone can tell me how to upload i would be grateful [/img][/code][/quote] |
23rd Jan 2013 11:13am |
DAMIAN Member Since: 24 Jan 2013 Location: spain Posts: 4 |
i have one door that does this so this weekend i am going to give it a go. makes sense, many thanks
25th Jan 2013 2:11pm |
