Home > Maintenance & Modifications > Moss / algae in window runners
Bogtrotter
England 2012 Defender 90 Puma 2.2 XS CSW Sumatra Black
Anyone have any ideas as to how to stop moss and other green stuff setting up home in the rear window channels ? And how best to remove it ?...without damage to surrounding paintwork.
Post #203239 19th Jan 2013 8:40am
K9F
I too had moss cultivating on mine. Decided a cover would be the solution.
K9F wrote:
Due to the fact the mileage I cover each year has drastically reduced my Landy gets used only very rarely and the size of my garage precludes storing it away. Last week giving it the once over I had to get my credit card out and clear the friggin' moss out of the top wing seam. Could have used Pathclear. Well have been considering it for a while and being in the marine industry am well acquainted with numerous contractors. Off to a cover manufacturer who makes all sorts, pick a decent 100% waterproof material, two guys one days toil and truck left so tailored template pattern can be made and then the final product. End result vehicle cover that I am pleased with. Not cheap due to material chosen but happy with.
Excuse poor photo quality but taken by manufacturer and sent to me. Because it rained most of the day I can't put it back on and take more photos until the rain stops and the vehicle is dry.
More info here:
http://www.defender2.net/forum/topic15754.html?highlight=cover If you go through life with your head in the sand....all people will see is an ar5e!!
Post #203241 19th Jan 2013 8:43am
try silicone spray, nothing will grow on that stuff
Post #203248 19th Jan 2013 8:59am
bob neville
Diluted solution of IPA (rubbing alcohol) and water, 25% IPA rest water.
Pour into channels and lightly scrub with an old toothbrush then pour in more solution.
Leave for an hour and then rinse with fresh water. Then use the silicon spray.
The IPA mix kills the algae Thumbs Up
2013 Defender 90 CSW - sold
Post #203261 19th Jan 2013 10:13am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Thanks Bob & BPman,
Same problem here so I'll certainly try that Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #203272 19th Jan 2013 10:33am
Lorryman100
I use the pressure washer, as the Algea only grows on the outside runners on mine. Thumbs Up
Post #203275 19th Jan 2013 11:05am
Bogtrotter
Thanks guys...will try the ipa solution. Steve w.
Post #203293 19th Jan 2013 12:10pm
Laurie
I thought 'window boxes' came as standard with every Land Rover.
Post #203295 19th Jan 2013 12:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Weedol or Pathclear, or any weed killer spray. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #203423 19th Jan 2013 7:01pm
rossy
I sprayed mine with Polycell Mouldkiller (triggerspray - from any DIY store) last year and it hasn't appeared since
Post #203433 19th Jan 2013 7:47pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
IPA should work, fine
I use this stuff as APC, All Purpose Cleaner, for mats, and general cleaning, also softening really stubborn grime...it also worked spot on removing Algae from the window seals on a RR Sport, using a soft brush, I used it diluted 1:10, but you could step it up if it was really tough.
I'd ass to a spray bottle, soak the areas a few times then use a tooth brush or detailing brush if you have one.
Post #407981 16th Mar 2015 10:06am
McGeordie
sorry, meant to attach a link!
Meguiars All Purpose Cleaner
http://www.cleanyourcar.co.uk/engine-and-e...d_321.html
Post #407983 16th Mar 2015 10:07am
or you could just go the opposite way and enbrace it:
Post #408995 19th Mar 2015 2:52pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
When the moss grows in the window channels of my S2A it prevents the windows from sliding open.
Had you considered that this might be a desirable extra security "layer"? Laughing 1970 Series 2A 88"
Post #409005 19th Mar 2015 3:23pm
