Home > Maintenance & Modifications > 2011MY Wiper Arm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
2011MY Wiper Arm
I need to remove the drivers side wiper arm from its spigot but am having difficuly pulling it off.
Have flipped up the cover, undone the nut and tried to pull off but nothing.
Can someone tell me, are they on spines on the spigot or is it held there by pressure from the nut?
Old pre 2007 ones used to have a collar with a gromet screw in it but this arrangement has nothing like that.
Post #203020 18th Jan 2013 4:57pm
Retroanaconda
Re: 2011MY Wiper Arm
Pre-2002 actually, but you're right. Older ones were a free splined fit, but a parallel spline.
The newer ones use a tapered spline held by the nut, as a result it will be a pain to get off. Give it some gentle wiggling via the arm. Just don't snap the shaft off!
Post #203043 18th Jan 2013 5:13pm
Martyn
I can see the spigot has a very fine spline to it.
Does the circular hole on the arm have a spline pattern to receive it Ie. going to be a Censored to prize apart or is it smooth?
Post #203056 18th Jan 2013 5:32pm
Retroanaconda
Think they're both splined.
Post #203132 18th Jan 2013 8:01pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Take the nut off and then put a few drops of 'Plusgas' on the splines. Leave overnight and it will come off with no effort at all. If you don't have 'Plusgas' then a few drops of diesel will also work, but it will take a little longer to penetrate.
Pete
Post #203161 18th Jan 2013 8:51pm
