Home > Puma (Tdci) > Relays under drivers seat
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
My first post, I am hoping somebody can identify the 3 relays under the driver's seat. I have purchased and partially installed a Waeco heated seat kit (wiring yet to do). My plan is to install an additional fusebox in the driver's seat 'box' so I can wire in the heaters. However, I dont know where to take a 15A switched feed from (I dont want to start pulling the existing fuse boxes apart yet) - would anybody know if there is a suitable switched supply under the drivers seat I could use?
Post #200637 10th Jan 2013 8:24pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The relays are for
ABS return pump
Starter
Glowplug
and Main Relay for harness
My car has 4 relays there - one of yours seems to be missing
Post #200663 10th Jan 2013 8:56pm
Generaldej
thanks, there is another 'black box' just out of view - its actually labelled fog light. Its a probably 3 or 4 times bigger than the other 3 relays. Dont know if thats your 4th relay. I have the the XL model which has no optional extras so probably has very basic wiring - the most sophisticated bit is the electric windows!
Post #200678 10th Jan 2013 9:21pm
kmac
PM sent re Puma wiring manual....all is revealed therein Smile
Post #200767 11th Jan 2013 10:03am
That one is the rear fog light "ecu".
The top photo does not show an ABS relay and I suspect that the vehicle in question is non-ABS.
(The ABS and optionally HFS relays would be on the extra mounting tabs at the lower right of the photo if they were fitted).
Post #200785 11th Jan 2013 11:04am
It is very unlikely that there is a suitable switched supply under the seat already.
You may want to consider adding a new axiliary fuse box in the seat locker, which can be powered either from a feed from the battery or from the feed that already connects into the existing fuse box (it is very easy to add a connection to the main feed on this box). If you opt for the latter, it will of course be fed by the 100A megafuse on the battery for added protection.
I suggest studying the electical manual you have been sent to see how the OE seats are wired, and then extrapolating the simplest way to achieve a similar effect. It is generally possible to get the same result in an easier way, give the difficulty of matching most of the factory connectors.
Post #200787 11th Jan 2013 11:12am
Generaldej
Thanks for the info - I see lots of reading ahead Thumbs Up
Post #200810 11th Jan 2013 12:34pm
Generaldej
Blackwolf - thanks again for all the wiring diagrams etc. I have got an auxillary fuse box which I do intend to connect to the main feed box. However, having never disconnected the battery before on this vehicle, is the any thing else I need to do apart from :
1. Switch ignition on to run position,
2. Switch ignition Off
3. Within 17 seconds disconnect battery
to stop the alarm going off
Will I loose anything from the ECU??
Post #200853 11th Jan 2013 4:25pm
I think the book says 15 seconds. You won't lose anything except probably the radio code (make sure you know what that is beforehand, it's on a card in a plastic bag taped to the battery when the vehicle leaves the factory).
Open up the battery compartment, get your spanner ready, then do the thing with the key, and you will have plenty of time.
Post #200870 11th Jan 2013 5:53pm
Ric
I've had a after market alarm fitted, but the ecu immobiliser is still active also, so do I need to keep the battery off time to less than 15sec? Confused its only a car!
Post #201107 12th Jan 2013 3:36pm
kmac
That battery disconnection procedure is for those who have the Land Rover Battery backed sounder installed. If you do not follow the procedure, the sounder will sound the alarm. No impact to ECU immobiliser. Hopefully your after market alarm also has a battery backed sounder in which case you will need to follow the manufacturers instructions on how to avoid alarm sounding when disconnecting the car battery
Post #201177 12th Jan 2013 6:53pm
