Home > Technical > TD5 trailer wiring |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 191 |
Hi guys
Any of you know what colours are which for re wiring the towing socket? Ive bought a new kit as old one was passed it. Colours i have on new one are: White Brown Green + Black Red + Black White + Black Red + Grey Black + Grey Grey looks a little purple! I know the standard coulours but cant find any info about this. Make on the cover of the socket is Con Wys.if that helps? Cheers Wil |
10th Jan 2013 6:21pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Is it a LR genuine parts kit or aftermarket? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th Jan 2013 6:56pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
http://www.towingandtrailers.co.uk/shop/132/133/142/index.htm
There's lots of info on google if this isn't quite right. I did mine recently was fairly easy. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
10th Jan 2013 7:06pm |
It has the part to plug in to the landrover but its not wired to the socket to which you put the plug in. I bought it from Swansea 4x4 so don't know if it is pattern etc. doesn't say whether it is or not a genuine and no instructions either
10th Jan 2013 8:54pm |
Stevie d. If it was in the standard colours I'd be able to do it but as first post says its in different colours
10th Jan 2013 8:57pm |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 |
I did this yonks ago and noted it down somewhere/ Will try to look it out but will be tomorrow. You'd think they'd be standardised.
10th Jan 2013 9:05pm |
It's not standard wiring colours - either Land Rover or generic 7 pin 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Jan 2013 10:22am |
Ah, sorry I can't help you as my car is 03 90 and the vehicle wiring colouring will be different between mine and yours. I did do this on my ex RAF 90 years ago but again the wiring colouring would be even more different. Sorry.
11th Jan 2013 10:30am |
Right, here we go:
Pin numbers are for a 7 pin 12N connector. Colour Function Pin # ====================================== White Fog Light 2 Brown Earth 3 Green + Black RH Indicator 4 Red + Black Brake Lights 6 White + Black LH Indicator 1 Red + Grey RH Side Light 5 Black + Grey LH Side Light 7 1988 90 Td5 NAS soft top 2015 D90 XS SW |
11th Jan 2013 10:46am |
Hope you got the kit very cheap as there are no instructions 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Martin you are a landrover god! I've spent hours on google trying to find something.
Ill get on it next, I think I paid about £25 ish. Thank god I've still got my D3! Many thanks for the help guys! |
11th Jan 2013 11:14am |
