Home > Puma (Tdci) > Grinding noise
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Grinding noise
I keep getting a grinding noise that I'm hoping someone can help me with. The sound comes from the middle to rear of my 110, and only happens at around 110-120 km/h, only on light or no throttle, but under compression. It's more noticeable when I'm negotiating a bend, as opposed to going straight, but does sometimes occur then. It's not a high pitched diff whine. Classic scenario would be when I'm going down a steep hill, with either a gentle left or right bend.
Thanks in advance.
Rob
Post #20058 14th Dec 2009 11:52am
Grockle
sounds like the diff 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #20059 14th Dec 2009 12:03pm
Niel
my "new" diff is making that same grinding noise. The old one never used to Puma 110 sw White
No extras yet.
Post #20073 14th Dec 2009 1:47pm
Grockle
it could need setting up properly to much back lash perhaps 2.4 90 XS
Post #20078 14th Dec 2009 2:50pm
felos
Greece 2008 Defender 110 Puma 2.4 CSW Epsom Green
It's the rear propshaft,nothing serious if you can stand the noise.The only cure is to change it with a TD5's one (from the "SALISBURY" rear Diff model). NOT A TRANSIT
Post #20085 14th Dec 2009 4:57pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I get this noise too. Can't say if it is less noticeable on a bend, but if this were the case it could indicate a diff.
Mine does it especially on a long journey when backing off the throttle between 100 - 120kph. It won't do it below 100kph. Comes from the centre/front. I have told the dealer who claims not to be able to hear it.
Austen Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #20106 14th Dec 2009 10:55pm
