Page 427 of 1376 <123 ... 426427428 ... 137413751376>
mk1collector wrote:
It'll be a slow few weeks job though trying to fit the work in around other chores Rolling Eyes
Tell me about it. Short day length, work to do and sometimes poor weather. A job that would normally take a day can take a week. Sad NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #199349 6th Jan 2013 11:31am
barbel jim
Bad but has a plus side - You know you're not going to get it finished, so you take you're time and do it properly. Then with the passing years you don't look at it and think If Only I'd !!!!!!
Post #199350 6th Jan 2013 11:41am
macduff
Replaced diff and transfer case oils. It's only got 16k miles under its wheels but had been used on shoots so thought it would be good to do. Front Diff oil came out grey, rear dark brown and transfer case like dark honey but seemed a bit thin. Diffs were easy but the filler plug on the xfer case was awkward and filling from the 1 litre oil cans tricky as the fill neck wasn't long enough to reach hole past the park brake and cable :/ . Old can wilth longer spout came to the rescue but with added pleasure of very slow flow rates. Gearbox next on the list but not until I sort out a better means for filling. 2023 110 P400e
Post #199360 6th Jan 2013 12:04pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I bought an oil syringe for doing this. It was a draper one and made the job a lot easier, all be it a bit messier too as the oil forced its way past the top seal and dribbled down my arms!
Post #199371 6th Jan 2013 1:09pm
macduff
Lol I'm still trying to get the smell of EP out of my beard. 2023 110 P400e
Post #199372 6th Jan 2013 1:20pm
mk1collector
Yeah I've got 4 kids too that have a very active social life so I have to bolt the seats back in every two minutes to take the kids out Big Cry
Post #199386 6th Jan 2013 2:16pm
bob neville
Yesterday fitted Defenderdors to the 90 and 110 plus restraining straps so i don't leave them at the petrol station.
Attacked the 90's gutter and roof seal with Captain Tolleys. The worst area was the join where the slope meets the flat on the curve on the drivers side. I think a fair amount of water could have got in via the gap.
Was going to repeat the treatment today but we have fog and light drizzle.
2013 Defender 90 CSW - sold
Post #199396 6th Jan 2013 2:57pm
Did a whole bunch of lanes in the Peaks.... The early start was worth it for the sunrise alone.
Luismi, thanks for making the trip worthwhile , I will be getting the photo's done this evening, not as many taken as you though Wink
You know, we did loads of gnarly lanes, with standard suspension, anti-roll-bars, side steps etc etc.
Great day.
Post #199421 6th Jan 2013 5:20pm
mk1collector
Ground off the surface rust that's started on the rear crossmember treated and primed ready for paint! I will get the defender looking nice one day!! But that day seems a long way away Big Cry
Post #199425 6th Jan 2013 5:43pm
Fitted my X-Eng gearstick lock:
More details HERE Darren
Post #199427 6th Jan 2013 5:48pm
3rd row seats out, cling film wrapped and stored, 2nd row ... considering removing them.
full underside visual check, rivets sealed, CB installed, checked and sealed floor, more insulation installed.
checked and listed all the kit - insurance being sorted this week
still waiting for a couple of electronic goodies from the USA ...
went up the road in the 90 ... not driven it for a while ... battery charging fine, wipers still not parking properly = job for next weekend.
saw BigRuss prior to him returning to work Sad
Post #199449 6th Jan 2013 6:20pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Finished the noise proofing, fitted the carpets back and they still fitted no need to adjust anything.
Fitted back board to mount the Amp, painted it black first then a little foam to absorb vibration. Couldn't find the fixing and I had every other size Big Cry it's tie wrapped for now. Replaced the speakers and fitted new head unit, just need to read the manual Whistle Whistle
Fitted dual USB charger and put the seats back. _______________________________
Puma Defender 90
Post #199502 6th Jan 2013 8:13pm
Nobby - Photo's please! NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #199505 6th Jan 2013 8:19pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Got some sides for my Hannibal awning so had a trial fitting this weekend. Really nice bit of shelter that is quick to put up and down.
The picture does not show it but it's a 2.4m awning on a Defender 90. I plan on getting a 4th wall made up to fill in the gaps and also draughts from under the vehicle.
Post #199516 6th Jan 2013 8:37pm
Nobby
Steve,
I will get round to it, just run out off time, it was "dark o"clock" when I turned in Embarassed I may need some assistance with the Amp and RCA cables, I'll PM you if that's okay Question
Nobby _______________________________
Puma Defender 90
Post #199525 6th Jan 2013 8:53pm
