Page 426 of 1380 <123 ... 425426427 ... 137813791380>
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
today I fitted these
and this...the old one was not working well - poor radio signal, volume buttons stop working - so found this one for 80€, no CD though, but with bluetooth, USB, Aux In, Ipod conect, etc....
and these, finally, after one year and half stored in a shelf...with a help of a friend who welds and works on metal for a living....
and fitted side hinges to the tailgate....now just have to get the tailgate painted....the hinges will be black...
 Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #198993 4th Jan 2013 7:26pm
Welshsurferdude
Wales
Took my winch comp 90 for its mot which failed on x2 rear wheel bearings and rear propshaft. Deep joy! More hub bearing work for me!!!!
110 having its wheel bearing replaced yesterday
BBCode Full Size
90 awaiting its impending doom of mot
BBCode Full Size
BBCode Full Size 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #198996 4th Jan 2013 7:43pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Jet washed 1/3 of Salisbury plain off of my 110, which then lead to a driveway clean up. As long as the rain holds off I will give it it's proper clean tomorrow after the gym. Time permitting all the door cards will come off for a clean and a lube of the locking and window mech. Strong people are harder to kill and generally more useful!
Post #199002 4th Jan 2013 7:57pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
BigRuss wrote:
warren wrote:
Having massive withdrawal symptoms, so had a cheeky look around a tidy 51 plate Td5 this morning... then my sensible side took over and went and bought an Astra Sad
I thought you said your sensible side took over??????
Think I should have replaced 'sensible' with 'boring' ha Confused Having said that the Astra is an absolute steal (not literally!) and the Defender was a bit overpriced...
Post #199061 4th Jan 2013 9:18pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Took a little drive out with my 2 lads yesterday and ended up doing a couple of lanes, my first of 2013.
Post #199141 5th Jan 2013 9:45am
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Well today I thought I'd install the new head unit, speakers etc, however thought I'd best finish the sound proofing of the cab Whistle . Took everything out and cut to size, then tidied the odd cable in the battery box. Found some non Land Rover cables routed into the back of the Head unit, exactly the ones where I will connect the new temperature gauge:!: Followed them back to a strange black box, rely type configuration mounted on a black plastic panel fitted on side nearest the door also noted small cable runs out and up passenger door frame Question No idea what it is or does Question
Anyway ran out of time so seats, runners all sat in the garage with speakers etc.
Still always tomorrow Whistle _______________________________
Puma Defender 90
Post #199199 5th Jan 2013 4:41pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
You have PM re the black box
Stripped my interior today and gave a good clean, blacked the dash, door cards, floor covering and rear liner, vacuumed and generally tidied up inside. Started to lay out all the kit for the Norway trip ready for packing into the storage boxes.
Will be cleaning outside next week starting with all the wheels off to remove the Salisbury glue.
Only 17 days to the Northern Lights Thumbs Up 2007 TD5 90 Hard Top
Post #199213 5th Jan 2013 5:49pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Fitted patriot rear cage to double cab
Think I'm going to spray rear door black
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #199221 5th Jan 2013 6:15pm
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
Drove my daughter home down m40
Post #199222 5th Jan 2013 6:20pm
mfspannerman
United Kingdom 2002 Defender 90 Td5 HT Oslo Blue
went shooting got defender covered in mud then washed defender and fitted new wipac cyrstal headlights what an improvement!! Smile Make tracks and get moving!!
PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT!
Post #199264 5th Jan 2013 8:08pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Re-arranged the bracket holding my Safari-Equip spare wheel carrier to the tub - it had started to stretch the rivet holes holding the corner rub capping causing movement and a geiger-counter-style ticking that was driving me potty. A couple of extra rivets and an extra bolt through the capping finally firmed things up...
After that I sorted out the central locking actuator on the offside rear door that had been tetchy lately. After much messing about realised the little bellows on the actuator was catching on the push rod and making it stick a bit.
Whilst I was in there found quite a bit of rust so I thoroughly drenched the door frame in Dinitrol 3125.
Then, if that wasn't enough, I started the job of soundproofing the rear after taking out the sodden rear carpet last week. Got the loadbay floor done but now need to do the seat boxes. Another day - or two...
Nice having a decent day to crack on with stuff... Dave
Green Goddess - 1998 Defender 110 300tdi
Post #199281 5th Jan 2013 9:09pm
excossack
Changed the wheel on the wifes Focus as the tyre had a screw through the shoulder of the tyre, luckily I had one of the original tyres to hand that was going to be used as a spare when I get 2nd hand rim.
So, a tyre that was 3 months old is now binned! and tip run 4 bags of rubbish and one builders bucket of Lilly trimmings.
All in the 110. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #199308 5th Jan 2013 10:19pm
dhopable
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Got some new tyres for its christmas present... (havent figured out if its a he or she yet) Confused
http://sphotos-e.ak.fbcdn.net/hphotos-ak-a...3320_n.jpg
And planning on fitting the Mud bulkhead removal bar and rails when they arrive this coming week..
My knees cant wait for the legroom!! Surprised
Oh and got some osram nightbreaker bulbs coming after reading the '5 best upgrades' post!! Thumbs Up
Post #199317 5th Jan 2013 10:52pm
leeds
A complete novel day today in the UK for me!
Have NOT driven a Defender or touch one. Feels completely strange to me.
Brendan
Post #199321 5th Jan 2013 11:16pm
mk1collector
The carpets have come out to start the mammoth task is stopping water coming in and prepping for dynamat. It'll be a slow few weeks job though trying to fit the work in around other chores Rolling Eyes
Post #199323 5th Jan 2013 11:43pm
