Home > Maintenance & Modifications > Defender thermometer? |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I've got the CheckTemp II - great bit of kit, and instructions here http://www.defender2.net/forum/topic5492.html
Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
6th Jan 2013 8:25am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Heres a picture of my temperature sensor:
Seen as we all run about with our windows down and elbow out If your arm goes a blue colour its cold. If it turns red it's sunny. If its wet its raining. Original Member Pie n Pea Club. 110 HCPU Tipper |
6th Jan 2013 9:43am |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
Got the check temp installed as well. The inside sensor behind the A pillar cover, slightly sticking out at the top. The outside sensor I put inside the tube of the raised air intake. After experimenting it seems to be a kind fo showing the true temperature, other places on the center console, the heater air intake, behind the bumper are pretty much influenced be the heating or aircon, engine and street heat.
6th Jan 2013 12:22pm |
Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336 |
My dealer fitted a VDO thermometer into the dash instead of the original clock, identical measurements. Costs were € 125,- for the item itself and appr. 100,- for fitting (again the limited knowledge when it comes to electronics....)
http://www.matzker.de/Technik-Zubehoer/fue...:3531.html Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th Jan 2013 9:59pm |
Is the same that sell by Mobilecentre
Click image to enlarge Click image to enlarge Click image to enlarge External sensor Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Jan 2013 10:09am |
