Home > Puma (Tdci) > Space Problem for a tall person. How to solve the problem?
bjartin
Norway
I need some good advice from a tall person.
I have test driven Defender 90 2.4 L and the SVX, and 110 2.4 L. My problem is that I do not have the support of the thigh on the seat because I sit too close to the pedals. I know the "Seat Riser" from Exmoor, but it does not provide much extra space (?).
What have you, who is 190cm, made to fit in a Defender?
Post #19910 12th Dec 2009 9:36am
110SEB
I'm 1.9m as well and am fine in our 110 sw. Perhaps it's something you just get used to? Have you thought about Mud Rails by Mudstuff? They'll give you several cm more distance from the pedals.
Either that or stop driving in high heels! Rolling with laughter Thumbs Up
Post #19911 12th Dec 2009 10:11am
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Mud Rails are the way to go, 30mm higher and up to 100mm further back.
http://www.mudstuff.co.uk/
On commercial models you also need to remove the bulkhead (they do a kit for this) see below.
I'm 185cm tall and don't have to have the seat all the way back, a friend is 196cm tall and he can drive his wife's 90 Hard Top with the same modification as mine no problems.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #19925 12th Dec 2009 6:17pm
discocuzzy
Mud rails as above...sonic is about 7ft tall and he looks out of the back windows at junctions Shocked You cannot teach stupid people to do clever things
Post #19931 12th Dec 2009 6:43pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mud rails, best modification!
Post #19936 12th Dec 2009 7:07pm
bjartin
Norway
In Denmark it is illegal to remove (or change) the bulkhead. I must also agree to have a "grating" behind the seat in the vertical extension of the bulkhead. This determines the fee to the State.
It's probably for the reason that the MUD Danish distributor does not mention a word about the bulkhead.
How many mm can the seat positioning come further back without moving the bulkhead?
PS
thanks for already received answers
Post #19937 12th Dec 2009 7:08pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Buy a 110 double cab or station wagon and you have no bulkhead to worry about Thumbs Up fit a set of mud rails and enjoy loads of legroom Thumbs Up
Post #19949 12th Dec 2009 9:09pm
Mad Cow
Not a lot according to Mud UK see HERE MAD COW
Project90
Post #19963 12th Dec 2009 10:51pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I'm 198cm and use the Mudrail, it's still tight on room though, you just have to get used to it.
I don't think there would be any point in using Mudrails in a vehicle that has a bulkhead in place, as the seats already hit the bulkhead at max extension.
Post #19971 13th Dec 2009 12:41am
discocuzzy
Thumbs Up If you get a 90 your pretty restricted. You cannot teach stupid people to do clever things
Post #19987 13th Dec 2009 11:49am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
bjartin wrote:
In Denmark it is illegal to remove (or change) the bulkhead...
Land Rover obviously anticipated this. In some markets they offer a special procedure to accommodate tall people. It is called an "LDS" or "leg deletion service" and has a part code of 'ch0p1t0ut'.
Obviously they only remove a small section of the lower leg to reduce you to the dwarf-like status of a 'standard' defender driver. Measured in LRU (Land Rover Units) you reach 1.7 LRU (around 170 cm). I think they also offer a knuckle and elbow deletion service for access around the steering wheel. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #20001 13th Dec 2009 2:13pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
discocuzzy wrote:
Thumbs Up If you get a 90 your pretty retarded.
There's no need for that shipmate Shocked Original Member Pie n Pea Club.
110 HCPU Tipper
Post #20002 13th Dec 2009 2:17pm
diffbeer
Is there not a new product out from exmoor trim that extends the seat's range?
Post #20077 14th Dec 2009 2:37pm
bob neville
Exmoor make a set of seat risers, they raise the seat by 40mm on the lowest setting and about 60mm on the highest.
I had two sets fitted in my 110 with the standard LR seats. I have taken them out for now as they don't fit the Exmoor Le Mans seats ?? !!
If I remember correctly, Sonic said he tried to fit the Exmoor Risers in a 90 on Friday and he had all sorts of problems and I think he gave up.
Bob
Post #20087 14th Dec 2009 5:13pm
