Home > Technical > Door adjustment help
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
When fitting my chequer plate sills today I hit a problem on the drivers side. Both doors need to go up a couple of mm to clear the plate.
As is they only just clear the normal sill especially the rear passenger door towards the back.
Question is, which part of the hinge has adjustment in, the part bolted to the door or the part bolted to the B pillar and bulk head, and are the nuts captive?
I'm sure some of you knowledgeable chaps have done this yourselves. Question
Cheers,
Chunk
Post #19917 12th Dec 2009 3:29pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I had to do all 4 doors to fit the sill checker plate Crying or Very sad
The door side of the hinge doesn't have captive nuts and the pillar side is the adjustment slot. It's a lot easier with two people.
One other thing to note is if you have a roof rack check that the re-alignment is not going to fowl the door on any gutter clamps. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #19967 12th Dec 2009 11:52pm
Chunk
All sorted thanks Very Happy
Post #20011 13th Dec 2009 3:33pm
