Home > Technical > What Oil Pressure? |
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 |
Hi,
I am after fitting an Oil Pressure gauge and am wondering what sort of pressure I would need. I have seen gauges up to 80psi, 100psi and 150psi. I am looking at a VDO oil pressure gauge. This is on a 2006 TD5 Defender, chipped, EGR removed, silicon hoses and straight through Terra Firrma pipes fitted with the one original rear box left. A McNally EGT/Boost gauge is going in at the same time. Any advice appreciated, Cheers, Col 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
4th Jan 2013 4:24am |
