Home > Maintenance & Modifications > Spotlight question sorry |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
What Di you mean? If the light stick is at first position from off ie sidelight setting the headlights are on? But dull?! 90 Puma HT
31st Dec 2012 6:38pm |
Another great mod, people fail to do is, especially as we get older....get your eyes tested
31st Dec 2012 7:09pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
What.... who said that? |
31st Dec 2012 7:20pm |
Ha thanks for the advice! Makes sense!! in my hilux I had 90-120 watt bulbs, put them in my 90 when I got it prior to knowing how pathetic the switch was and yes it died! Had to put me another stick etc in!! Still got the bulbs though! 90 Puma HT
31st Dec 2012 7:52pm |
Got a link for arb wiring jobby? 90 Puma HT
31st Dec 2012 7:55pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
You can buy a ready made, excellent quality, wiring loom with all relays, plugs and fuses etc: from here
https://shop.landreiziger.nl/modificatie/m...elais.html Site owner/seller is called Martin. Fantastic service and writes and understands English . Fitted easily except for the connection to rear of alternator, that is virtually impossible without removing the alternator, so I chickened out and wired a heavy duty supply direct from battery. Works really well. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
31st Dec 2012 8:31pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Do not forget that headlights are powered through the on/off switch. Upgrading the wiring with relays can provide a useful gains . Its what I would do first, however when travelling long distances at night I have my lightforce genises, wide angle and spot.
1st Jan 2013 1:48am |
Is Martin on here? Think ill get one! 90 Puma HT
1st Jan 2013 9:12am |
I can't find the actual ARB schematic, but googling "headlight relay diagram" brings loads up.
They're all much of a muchness. 2 or 3 relays (presonally i'd use 3... one for both dipped, then one for each main beam... or just 2 but the high current 30amp relays) |
1st Jan 2013 11:15am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
The Nakatanenga LR-STD-NARK relay harness here is well made kit.
Brendan |
1st Jan 2013 12:17pm |
Brendan,
Interesting to read that Nakatenga website say that it even makes sense to use their relay harness even for Defenders having installed Speakers which consume only 35W each instead of 55/60W. I presume that has nothing to do with more light as believe to understand that as long that the Speakers get minimum 12V fed, there is no difference in light emitted if there would be 13V or more reach the lamps.... I once asked Tim abt such relay, and he said no need... Nakatenga say that even with the 2X35W there is a risk of burning the Defender light switch, albeit at a later moment... In your opinion, does it make sense to use a relay with Speakers, or not? If so, pls note that I have an SVX, so the aux high beams already run via a relay. I further have halogen fog lights which also are routed via separate relays, actually the fogs specifically now run via 3 relays to avoid any interference with the Speaker electronics which initially proved a problem. I also have a Alive DRL bumper which is also powered via a separate relay. If it makes sense in my case to have the Speakers also run via a relay, which of the 6 relay options on the bottom of the Nakatenga website do I need for the Speakers? Do you offer these products, or would I have to order direct from Nakatenga? Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st Jan 2013 12:51pm |
