![]() | Home > Wheels & Tyres > Wheel weights. |
Can't think of any reason why not.
My ZU's have stick on weights on the inside rim. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
TBH clip weights are better as the futher out the weight is the less weight is required
speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102 ![]() ![]() ![]() |
I believe they use knock on weights on 4x4 vehicles because if you go off road the weight wont come of , but if you have stick on theres a chance it will come off thats what im lead to believe ( no pun intended )
rs2315 Member Since: 16 Sep 2012 Location: yorkshire Posts: 125 ![]() |
Thanks for the reply's, I'll get the weights put on the inner after I get the boosts refurbed.
Just seems daft to put clip on weights on that scratch the paint, and then corrosion sets in. rs2315. |
totalal Member Since: 26 Dec 2012 Location: Pembroke Posts: 36 ![]() ![]() ![]() |
I've found when you change your tyres and the stick on weights are removed the glue is a
![]() Al 01 Defender 110 Crew cab TD5 07 Discovery 3 TDV6 XS ![]() |
Most good shops use a plastic knife
to remove the residue a good ol heat gun with mild solvent works the reason the shop wont do it is time as you wont pay for the extra labour ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I have had issues over the last year re tyre balancing and have asked for advice here. As usual the Def2 guys have been spot on. To summarise :
Wheels + tyres on these vehicles can take a lot of weights to balance (often well more than 100g - most tyre fitters are taught that more than 50g is bad news - not so with a Defender ! - you have to tell them or they'll just say your wheel/tyre is faulty !) Ken is right. Clip on is best but often a combination of clip and stick-on weights is whats required to achieve the magic zero reading on the wheel balancing machine. Don't worry because I've learned that even a week after balancing the wheels they're going to be out by 10-20 grams again due to mud or small stones in the treads ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Also the road salt can cause the stick on weights to fall off, as I have found out when I lost 150g of the front left wheel and the resulting wheel wobble I had to suffer until they were re balanced. Now I stipulate that they use the clip on weights on all the tyres I fit to the Defender.
My most recent set has them ![]() ![]() Click image to enlarge Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2696 ![]() ![]() |
You're driving a car with exposed door hinges and external roof gutters. Old school is the point...
Clip on is the way forward ![]() |
Stick on weights suck, after having my wheels done, the weights just fell off on the drive. Had them done again and I decided to remove the wheels to grease the backs of them, knocked the wheels on the dust plates and the weights ended up on my drive
I agree....whatever next? LED lights, big wheels n boomin' ICE? ![]() |
Anyone used balancing beads at all?
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I vaguely remember years ago of them being used to balance a couple of trailer wheels that blew out on me on the Motorway, super singles on an Artic.
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
All our trucks have balancing beads, My Land Rovers have had them in the past, currently running clip on weights. (alloys will be refurbed at some point. |
