Home > Wheels & Tyres > Wheel weights.
rs2315
Wheel weights.
My 110 is on Boost Alloys, and it has weights on outside of rims, and inner also.
The weights are the nasty clip on ones that wreck the paint.
My question is can I get the adhesive type weight, and have the weights attached just to the inner part of the rim Question
Seems real old school to have clip on, and also on outer part of rim Rolling Eyes
My Audi is running alloys and all the wheel weights are fitted to the inner part of the rim.
Would like your views.
Cheers.
Happy New Year to all.
rs2315.
Post #197717 31st Dec 2012 11:43am
bob neville
Can't think of any reason why not.
My ZU's have stick on weights on the inside rim.
2013 Defender 90 CSW - sold
Post #197730 31st Dec 2012 12:32pm
TBH clip weights are better as the futher out the weight is the less weight is required Thumbs Up
Post #197733 31st Dec 2012 12:47pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
I believe they use knock on weights on 4x4 vehicles because if you go off road the weight wont come of , but if you have stick on theres a chance it will come off thats what im lead to believe ( no pun intended )
Post #197751 31st Dec 2012 1:36pm
rs2315
Thanks for the reply's, I'll get the weights put on the inner after I get the boosts refurbed.
Just seems daft to put clip on weights on that scratch the paint, and then corrosion sets in.
rs2315.
Post #198137 1st Jan 2013 3:42pm
totalal
Wales 2001 Defender 110 Td5 DCPU Tonga Green
I've found when you change your tyres and the stick on weights are removed the glue is a Censored to get off the wheel. Brake dust then gets into the old glue and leaves a lovely black mark. The tyre fitter will probably cut the old weights off with a knife and scratch your alloy. (had a set of Freestlye alloys on my last 110 with matching scratches). The glue is obviously good otherwise the weights will come off. I've tried all sorts of products to get this old glue off without complete success. Therefore I always go with knock on weights, less damage in the long run.
Al 01 Defender 110 Crew cab TD5
07 Discovery 3 TDV6 XS
Post #198158 1st Jan 2013 5:07pm
Most good shops use a plastic knife
to remove the residue a good ol heat gun with mild solvent works the reason the shop wont do it is time as you wont pay for the extra labour Thumbs Up
Post #198191 1st Jan 2013 6:58pm
rossy
I have had issues over the last year re tyre balancing and have asked for advice here. As usual the Def2 guys have been spot on. To summarise :
Wheels + tyres on these vehicles can take a lot of weights to balance (often well more than 100g - most tyre fitters are taught that more than 50g is bad news - not so with a Defender ! - you have to tell them or they'll just say your wheel/tyre is faulty !)
Ken is right. Clip on is best but often a combination of clip and stick-on weights is whats required to achieve the magic zero reading on the wheel balancing machine.
Don't worry because I've learned that even a week after balancing the wheels they're going to be out by 10-20 grams again due to mud or small stones in the treads Thumbs Up
Post #198234 1st Jan 2013 9:20pm
Lorryman100
Also the road salt can cause the stick on weights to fall off, as I have found out when I lost 150g of the front left wheel and the resulting wheel wobble I had to suffer until they were re balanced. Now I stipulate that they use the clip on weights on all the tyres I fit to the Defender.
My most recent set has them Thumbs Up
Brian.
Post #198237 1st Jan 2013 9:27pm
Retroanaconda
You're driving a car with exposed door hinges and external roof gutters. Old school is the point...
Clip on is the way forward Smile
Post #198240 1st Jan 2013 9:31pm
Stick on weights suck, after having my wheels done, the weights just fell off on the drive. Had them done again and I decided to remove the wheels to grease the backs of them, knocked the wheels on the dust plates and the weights ended up on my drive Mr. Green
Post #198271 1st Jan 2013 11:06pm
I agree....whatever next? LED lights, big wheels n boomin' ICE? Laughing
Post #198273 1st Jan 2013 11:08pm
K9F
Anyone used balancing beads at all?
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #198282 1st Jan 2013 11:32pm
Lorryman100
I vaguely remember years ago of them being used to balance a couple of trailer wheels that blew out on me on the Motorway, super singles on an Artic. Thumbs Up
Post #198286 1st Jan 2013 11:40pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
All our trucks have balancing beads, My Land Rovers have had them in the past, currently running clip on weights. (alloys will be refurbed at some point.
Post #198324 2nd Jan 2013 10:23am
