Home > Technical > Ticking noise
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
Ticking noise
Hi all
I have owned a 300tdi 90 for the last year and have loved driving it but I have noticed its making a ticking noise when accelerating have taken it to a garage (not a landrover one) and to start with they thought it was coming from one of the injectors but then they started to think it might be coming from the front of the engine cambelt area either cam belt or fuel injector pump. I am also having starting problems when it's been left for a while as if fuel problem has had new glow plugs.Its R reg and covered 118000 odd miles.
I am not overly mechanically minded but iam willing to try if its not to hard a fix
Many thanks in advance
Post #196839 27th Dec 2012 8:57pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Ticking when accelarating can come from an exhaust manifold gasket blowing,this is heard more when accelarating due to the higher pressure in the system it is hard to replicate when just revving the engine with no load.The starting problem may be a seperate issue a worn fuel lift pump is a prime suspect on a Tdi.Keep us posted. 2005 Td5 90 XS
Steve
Post #196853 27th Dec 2012 10:10pm
Tia4
Thanks Lou
Have managed to hear the noise when just reving the engine while stationary could this still be exhaust manifold is there a way to check this out. Also fuel lift pump is there away to test this.
Post #196858 27th Dec 2012 10:26pm
Have the Tappets been checked, Rockers and caps etc?
Post #196860 27th Dec 2012 10:31pm
Lou Sparts
Look for soot marks around exhaust manifold area, this may not always show a leak though as it may be in an inaccessable area.The fuel lift pump lets fuel run back to the tank when it is worn and this then leads to poor starting as it needs lots of cranking to get the fuel up to the pump.You can check the fuel pump by opening the bleed screw on top of the filter housing and operating the lift pump by hand if you get fuel out straight away then it is probably o.k if you get lots of air before any fuel comes out the it is probably on its way out.A fuel lift pump is only £25-£30 so at your mileage is probably worth changing anyway.I hope this has been of some use to you. 2005 Td5 90 XS
Steve
Post #196868 27th Dec 2012 11:00pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
This is usually a sign of a cracked or warped head
Post #196879 28th Dec 2012 12:30am
Tia4
Foxkilla this does not sound good any other signs to look for ?
Greeni is this a simple job what would I be looking for I am bit of a mechanic newbi but willing to try
Post #197191 29th Dec 2012 10:02am
Swapping a fuel pump is a really easy newbie job.
Worth buying a Haynes manual but also search on YouTube
Post #197202 29th Dec 2012 10:46am
An engine speed related ticking or tapping noise on a 300tdi is quite likely to be a worn vacuum pump. Not hugely complicated or expensive to fix IIRC (it's a long time since I last had one of these). It's always difficult to diagnose sounds over the Internet though, so I'd suggest finding a good independent Land Rover garage who will know what they're looking at. Darren
Post #197215 29th Dec 2012 1:01pm
foxkilla
I had a ticking on a 300 which was none of the usual things and as a last resort I pulled the head and found a crack between bore and I think an oilway.this was only opening when very hot, and often gave the impression of being speed dependant.
Post #197237 29th Dec 2012 1:51pm
Take the cover off and have a quick look, as said above, a Haynes manual is a money saver.
Post #197243 29th Dec 2012 2:09pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Mine was a cracked head .... Have fun be happy
Post #198131 1st Jan 2013 2:14pm
Siggy79
United Kingdom 1996 Defender 110 300 Tdi CSW Epsom Green
Had same on mine and turned out to be vacuum pump had split along rivets.... Easy fix to swap though .. Forum newbie ....
Post #210804 12th Feb 2013 8:42pm
