Home > Technical > Puma fuel tank skid fit 200/300? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
I think it should do. the Td5 skid plate (same as a puma AFAIK, as the tank is the same) is more or less the same as the NAS 90 had as well.
The chassis rails are the same distance apart, so I'd say with a little bracket fabrication (To bolt the guard to) it should work. I've got a lot of close up pics of the Td5 90 tank brackets if you want any.... PM me your email. |
28th Dec 2012 4:58pm |
ini88 Member Since: 28 Nov 2012 Location: United States Posts: 16 |
Thanks Jim! yeah same part number as the TD5. Just wondering if its a straight bolt up to the 200/300 or I could get a 200/300 skid for it instead. someone is selling a puma skid for cheap thats why I was wondering.
28th Dec 2012 7:04pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8099 |
110 i take it? i n which case yes. 90 then no as tdi 90 had under seat tank. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Dec 2012 7:44pm |
yup! sorry about that, its a 1988 Defender 110 which incase its in the rear of the truck. |
28th Dec 2012 7:51pm |
