Home > Technical > Puma fuel tank skid fit 200/300?
ini88
United States
Will the new Puma/TDCI fuel tank skid fit the older 200/300 chassis? I know the rear chassis is a bit different on the Puma but I think that is only for the tub.
Post #196953 28th Dec 2012 3:09pm
I think it should do. the Td5 skid plate (same as a puma AFAIK, as the tank is the same) is more or less the same as the NAS 90 had as well.
The chassis rails are the same distance apart, so I'd say with a little bracket fabrication (To bolt the guard to) it should work.
I've got a lot of close up pics of the Td5 90 tank brackets if you want any.... PM me your email.
Post #196984 28th Dec 2012 4:58pm
ini88
United States
Thanks Jim! yeah same part number as the TD5. Just wondering if its a straight bolt up to the 200/300 or I could get a 200/300 skid for it instead. someone is selling a puma skid for cheap thats why I was wondering.
Post #197046 28th Dec 2012 7:04pm
jst
110 i take it? i n which case yes. 90 then no as tdi 90 had under seat tank. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #197062 28th Dec 2012 7:44pm
ini88
United States
yup! sorry about that, its a 1988 Defender 110 which incase its in the rear of the truck.
Post #197064 28th Dec 2012 7:51pm
