![]() | Home > Technical > Wipers wont return home |
The park switch is a common failing part, regardless of VW mod
GSD Member Since: 18 Dec 2012 Location: UK Posts: 38 ![]() |
Many thanks Greeni,
I'll put the 99 back in and get a spare park switch ![]() |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
A happy coincidence this thread has be resurrected as mine started to act up a few days ago.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Just done mine last week.
Put up with none parking wipers for months as they would park with wash wipe, or intermittent but not if on normal wipe, but then the park switch failed altogether so the only way to stop my wipers after wash wipe, or intermittent was to turn ignition off. Not nice job to do as I have air con ![]() Andy |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 819 ![]() ![]() ![]() |
Wise to fix this with a new part as soon as possible, if you ignore it the broken part of the switch can cause a short and blow the fuse usually when its pishing with rain
![]() Ask me how i know ![]() Last edited by rustandoil on 31st Dec 2012 2:28pm. Edited 1 time in total |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
I suffer this problem. I have managed to suss out the timing on flicking the wiper blades so they park roughly at the bottom of the screen now. My intermittent has turned into always on speed too, so I have to play flick the wiper blades on (and off) by hand at the moment. With the drizzle we've been having recently, this skill seems to be required every time I venture out. How I pray for more clement weather! When I initially bought the Defender I prayed for storms and snow so I could relish 'going anywhere' - times soon change!
Question: Would the intermittent timing problem be a fault with the park switch too? (I'm guessing it is in the 99.99% park switch blame) P.S. Found the very handy:
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
^^ useful info
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5940 ![]() ![]() ![]() |
Glad I found this topic. My 1999 td5 has just started doing this. Looks like a new park switch. 1999 Defender TD5 110
