Home > Puma (Tdci) > Safety Recall
Page 2 of 3 <123>
YORKSHIRELAD
Re: Safety Recall
Fjord wrote:
YORKSHIRELAD wrote:
mse wrote:
Anyone else had this today?
Park Brake Oil Contamination 2007 and 2008 MY
Aye, I got one Mike.
Received mine this morning also.
I'll kill two birds with the one stone and have the rear de-mister looked at while it's in as both the top and bottom elements are Censored . I'm presuming this is covered under warranty?
My went in a couple of weeks ago for the same reason.Two of the elements were duff. They just put a new rear screen in under warranty. 1963 Series 2A truck cab
2008 110 SW
Post #19534 5th Dec 2009 6:41pm
Fjord
Scotland 2008 Defender 90 Puma 2.4 XS CSW Cairns Blue
Re: Safety Recall
Thanks for the info YORKSHIRELAD ... a complete replacement suits me Cool
Post #19538 5th Dec 2009 9:16pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
well i guess this makes me famous or provious that customer services listens, my hand brake failed early this year and is in the vin range, i also got some damage due to this, Cool i started a recall Thumbs Up
on a serious note i park rear down hill at about 20 degree's so i guess it pool'd quicker in the drum, lesson learn'd leave the car in gear!
Post #19551 6th Dec 2009 12:34pm
Eduardo
I checked my logbook and I had this problem at the beginning of 2008 (10.000 km). It was repaired but I'm afraid that the repair made at that time was with the same system than the old.
So I will paid a visit to the dealers soon
Cheers! Eduardo
Post #19553 6th Dec 2009 4:13pm
nickhodgson
This is the same felt washer that they have been using for ever and this is the first "safety recall"!! Amazing.
In the text of the recall document under technical Q&A item 8 says replacing the felt washer with a rubber one!!! Seems that their quality assurance is not too great.
Post #19648 8th Dec 2009 7:11am
chalky
Received my letter this morning, this is after it went in for this in June, as with most others on here it hasnt worked,
Its wet thro all over the outside of my drum Evil or Very Mad DEFENDER XS CSW 08 TONGA GREEN
Post #19668 8th Dec 2009 6:23pm
Eduardo
Hello there!
Just I took contact with my Dealer and they still not receiving the VINs affected and the spares to do the job. So, I'm stil waiting to receive the letter.
Cheers Eduardo
Post #19705 9th Dec 2009 12:15pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
My dealer phoned up yesterday to tell me about these.
They said my VIN was identified as being within range of the park brake recall. They also described another "recall" around the MIL combined with a loss of power from a sticking high pressure rail control valve. I looked this up and it isn't technically a recall but is fixed with a software update for the PCM (powertrain control module). The code for this one is Q068v4_UK (or ROW for non-UK).
Summary below:
"When driving following a cold engine start where the engine coolant temperature is <5>35° and a gear change is made at an engine speed of
>2000rpm there is a possibility that the High Pressure rail control valve can stick and cause high
rail pressure, which trips a diagnostic, relieves the rail pressure causing the customer to see an
engine Malfunction Indicator Lamp (MIL) light on with restricted performance and P1169 and/or
P0089 Diagnostic Trouble Code (DTC) stored in the Powertrain Control Module (PCM).
Action to be taken
You are requested to contact the owners of the affected vehicles and request that the vehicle is
made available at the earliest opportunity for the vehicle to be inspected and where necessary
reconfigure the engine PCM with the latest calibration files." One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #19826 11th Dec 2009 11:42am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yep Alan Thumbs Up mines going in for the recall and the update to the software, been needing the software for a while just haven't got round to it. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #19827 11th Dec 2009 11:53am
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
ECU upgrade and oil pane so far. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #19830 11th Dec 2009 1:45pm
alantd
Your arm's changed colour! One that started out as a 2.4 TDCi 110 XS
Post #19831 11th Dec 2009 2:05pm
willy eckerslike
It's winter Original Member Pie n Pea Club.
110 HCPU Tipper
Post #19834 11th Dec 2009 2:10pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Got me a bit concerned as mine was registered September 2007
But just checked and the VIN is about 700 before this Very Happy MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #19849 11th Dec 2009 7:42pm
Eduardo
Sorry to go up this post
After one month asking for this to the dealers, today the spares needed to make the change arrived.
So we will be on the dealers next week, probably, to make the change (together with one electric door lock that doesnt work).
One question. ¿How much time should take?
Thanks Eduardo
Post #22131 14th Jan 2010 9:19pm
Hans
France 2008 Defender 110 Puma 2.4 SW Keswick Green
Thanks
Mine will be in next week for P019 and Q068: two hours the dealer said. Hans
http://www.orlaya.fr
Post #22149 15th Jan 2010 7:07am
Page 2 of 3 <123>
