Home > Maintenance & Modifications > I'm going to regret asking this but...................
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
The saying goes 'no such thing as a stupid question'......therefore here we go!!
Having just fitted an new anti lag system on a mates WRC Escort cosworth rally car.....believe me the difference is amazing and sounds fantastic.
Can you do the same to a turbo charged deisel??? Shocked
It obviously wouldn't spit flames and pop and bang due to diesel needing compression to combust, but the principle must be similar??
Just thought i'd ask!! Confused
Post #19609 7th Dec 2009 6:49pm
dgardel
Italy
ALS or BANG BANG SYTEM how to work
it's principally work on petrol car where you can "spray" fuel when the throttle is closed and control the amount of fuel came out from the exhaust valves
It's impossible to apply in a diesel engine (remember the diesel engine is a "self combustion engine" , petrol need spark plug, in a diesel engine you haven't throttle valves, you haven't the possibility to switch off the spark plug because you haven't the spark plug,.....) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19634 7th Dec 2009 10:24pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Think hes on about a dump valve to keep the turbo spinning as you change gear?
Ive heard of it done on a few diesel cars but not a land rover, it must be possible but how much it will benefit performance i dont know.
Post #19641 7th Dec 2009 11:43pm
chalky
No, ANTI LAG is nothing to do with the Wastegate.
Anti lag is as far as i am aware a crude method of keeping the turbo spinning by dumping un metred fuel and air in the inlet manifold pre combustion which in turn gets burnt creating the pop and bang at the business end, apart from looking good it has its benifits in assisting launch control and also holds the turbo on boost whilst sliding or partaking in the old scandanavian flick.
Listen to the cars go off the line on a rally stage and you can hear the anti lag kicking in, just holding the revs at 6K wont help as the thing will just bog down off the line as there is no boost just good old fashioned Lag.
Its OK for the big Rally teams "or not" as more recently most have folded, because if a turbo blows it gets replaced, the downside of popping and banging is blown turbos or the impellers detonating and getting sucked thro the cylinder head..........
I had a UR quattro some time ago which had the crudest means of Anti Lag installed and my god did that thing shift off the line, DEFENDER XS CSW 08 TONGA GREEN
Post #19644 8th Dec 2009 12:27am
Glynparry25
There is only 1 reason people put a dump valve on a derv and that is for the sound......and show off. Even on a petrol car a BOV is pretty pointless, all it does is save the turbo for a few more thousand miles.
Glyn
Post #19667 8th Dec 2009 6:21pm
discocuzzy
Oi Shocked was the nuts on my imprezza RB5 limited edition! Thumbs Up but as im not welsh, i was trying to woo proper chicks, not sheep! You cannot teach stupid people to do clever things
Post #19680 9th Dec 2009 12:44am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yeh............but our sheep are better looking than your chicks Rolling with laughter Original Member Pie n Pea Club.
110 HCPU Tipper
Post #19684 9th Dec 2009 6:48am
discocuzzy
You may have a point there Pete! You cannot teach stupid people to do clever things
Post #19689 9th Dec 2009 9:05am
willy eckerslike
Sorry Higgers, you've been hijacked
yeh and spit roasting a sheep is far better for you, specially if you cook it afterwards Original Member Pie n Pea Club.
110 HCPU Tipper
Post #19703 9th Dec 2009 11:47am
discocuzzy
Rolling with laughter Rolling with laughter Rolling with laughter You cannot teach stupid people to do clever things
Post #19713 9th Dec 2009 2:03pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I nearly fell off my seat with that comment willy Rolling with laughter Rolling with laughter
Post #19716 9th Dec 2009 2:11pm
Higgers
Don't worry Pete,
I've just been staring at your Avatar and its just clicked. Rolling with laughter Rolling with laughter
I think i need to get my eyes tested. Laughing
Post #19738 9th Dec 2009 5:08pm
